Thank you all
   / Thank you all #11
We don't get as much snow as some of you, but here's my 2 bits worth. I started out with a FEL and rear blade on my BX. It worked great, but if the snow fall was heavier, or the drifts got bigger, I had my work cut out for me. I then got tired of doing most of my plowing backwards, so I took the bucket off, and rigged a blade on the front, complete with power angling. This was better, but the bigger snowfalls had me working harder/longer (I guess I get carried away at the neighbours too). Last season I bought a rear blower, so now I can windrow the snow, when it gets too deep, I hit it with the blower. Works great..........except now I get all this cold snow blowing back at me...........so I am anxiously awaiting my Curtis Cab. I also play around with aviation, not sure which hobby is more expensive. /forums/images/graemlins/grin.gif
   / Thank you all #12
</font><font color="blue" class="small">( I I'm not sure I made the correct choice NOT to buy the snowblower. Your ideas? /forums/images/graemlins/smile.gif )</font>
Like the others have said, you don't need a snow blower. The fel will handle it fine. But you might want a snow blower if time is important to you. It takes longer with the loader, sometimes a LOT longer, depending on the snow conditions.
   / Thank you all #13
I have both the blower and the blade. I switch back and forth between them based on the amount and type of snow. I have a 300' gravel drive that I plow until the ground freezes and I am not killing squirrels with flying rocks ....after that I usually use the blower.
I would dread the thought of using the fel here as I would run out of snow storage very quickly.
   / Thank you all
I guess time is important for me in the winter, I make a living keeping homes warm. I will look into adding a blower. I liked the cab made from the golf cart cover, trick. I know I couldn't add a hard cab this year. RI winters can be no snow if the winds come off the warm ocean. Other years we get slammed.
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
