Thanks for help..JD 3320 Arrived
   / Thanks for help..JD 3320 Arrived #21
Mcad, Thanks for the note as this blade has the same bent blade stand pole. I wondered what might have happened and now I kno. I will get another and do as you said reference yellow.
Jim
Jim:
I forgot to post pictures of the stands I made. It's nice to have a couple of spares if I ever screw up again.
I suggest you get the end plates for your blade. I bought them and they are worth the money as they give you more control over directing the spoils you scrape up, especially if you only put one on and angle the blade to direct the spoils to the side without and end plate.
Will do Mcad. I will check into the end caps. Nice job of the stands!
Jim
   / Thanks for help..JD 3320 Arrived #24
Jim:
It looks like those homemade end plates will be used for snow removal. I doubt they would hold up to doing earthwork.
I bought mine as I had no way to fabricate a set at the time. Now I have the tools to do a set halfway. I have no way to bend a mounting flange like Deere/Frontier/Woods did, nor do I have a way to punch square holes. Of course a fab shop could have done those tasks for me; but probably at a higher cost than just buying them.
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
1992 SHOP MADE CHASSIS TRAILER (A53843)
1992 SHOP MADE...
KUBOTA M7-132 (A53084)
2015 DODGE RAM...
2019 TerraGator 7300 Spinner truck (A53473)
2019 TerraGator...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
