The best grooming mower
   / The best grooming mower
I am very new to this and I get the feeling my dealers might be trying to sell me to much deck. Do I need to go to a smaller deck? The tractor ways 2000 pounds what weight group should my deck be in?
   / The best grooming mower #13
Well, are you sure that you want a RFM (rear finish mower)?, or would you rather have a MMM (mid-mount mower)?.
After some more research I am considering a flail mower.
Caroni TL1500FSC 59" 88 blade 485lb. I have decided agility and less weight is key for me. What do you think? Am I on the right track?
   / The best grooming mower #15
Depends on what your trying to achieve. If you want a nicely groomed lawn, than a flail mower can give a fairly decent cut with sharp blades. Albeit not as nice as a pure finish mower, but it will be close. Have you decided on whether or not you do in fact want a rear mower?, or would you rather have a mid mount mower? If you like the feel of a riding mower than you could get the 62D "drive over" 62" mid mount mower deck for the 2x20 series tractors.
   / The best grooming mower #16
If you want a flail make sure you get one with grass flails on it. They are different than brush or heavy duty flail knifes. on my Alamo they attach differently with a pin instead of a d-ring.
If you are just mowing grass, a grass knifed or fine bladed flail will mow great...but don't use in brush it will destroy the knifes. for general grass and light brush use a standard duty knife and it will mow very well. Hammer knife or forged knifes mow very tall wet grass and brush very well.
My knifes are well worn but I still like it better than my Rear finish mower or my zero turn on the year yard!!
Jeff
   / The best grooming mower #17
As mentioned, I have a 2520 and use the Frontier GM1072R. I have very hilly property and I have to mow in 4WD all the time. I also keep the loader frame on and have three rear wheel weights per side.
While it is a little bit of a handful for the tractor to move around, I have been absolutely thrilled with the cut quality. In fact, I think the cut quality is better than the 62D MMM, mainly because the rear mower follows the contours of the land better.
I've used it for 2 1/2 seasons now with no problems. The 2520 has plenty of power for this mower, so I'm sure the 2720 could handle it.
Best of luck with your decision.
   / The best grooming mower #18
I would have to agree with you there Runner.I've been cutting Seven Acres with a Frontier GM1060R made by Woods and it's great.The only thing that I had to do to it in Eight yrs. was replace the belt it had a cut in it and keep the blades sharp.24 Hp. and 20 pto is plenty power for what I use it for.HKCHEF Speaking of dealers I use a 5103 for a widow I help out you should see the lip go up when they see or I tell them what I use it with.
   / The best grooming mower #19
Maybe you ought to take that money and spend it on some higher ground:p All kiding aside, I have a
Bush Hog brand RDTH finish mower, 60 inch and built like a tank. No problems in 6+ years (other than a pain to clean the underside). Sorry to hear about your flooded property. Always hate to loose those mature trees (among other things).
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2021 CATERPILLAR 299D3 XE SKID STEER (A52705)
2021 CATERPILLAR...
LONG 2360 TRACTOR (A54756)
LONG 2360 TRACTOR...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
