What I have long wondered about is that the automakers try to make full size trucks lighter, BUT they use huge 20 inch rims and tires on many models and the extra weight doesn't seem to matter to them. My '90 F-150 was the last pickup I owned and the steel wheels and 15 inch radial tires were a LOT lighter than the 20 inch aluminum rims and tires available on today's trucks. The new 20 inch tires wear no better than the older 15 inch ones and cost a lot more in addition to being much heavier. It makes no sense to me. Just imaging the weight savings by reverting to the older 15 inch rims and tires AND you could also have a compact spare tire then rather than the gigantic heavy 20 inch spare tire and wheel.
Not sure why you believe that the larger aluminum wheels, and low profile tires, are heavier than the steel wheels, and high profile tires.
I handled hundreds of them over the years. And, that was not what I experienced.
The outside diameter of the tire is the same. The inside diameter is the only thing that has changed. And, while it will give better handling performance, it was done, to save weight.
Aluminum is obviously lighter than steel. Even though the wheel is a larger diameter, it's made from a much lighter material, than steel. Low profile tires, have a side wall that is often less than half the height of a normal tire, which means less rubber. Rubber is very heavy, just the weight saving there, is substantial.
Cars and trucks are now treated the same way as aircraft, in the sense that every bit of weight they can save, matters. The government is forcing them to find ways to increase mileage anywhere they can. Manufacturers have completely eliminated spare tires on most cars now, to save that weight. If the old steel wheels, and tires, would save weight, they would go back to them in a heart beat. Not to mention steel wheels were a lot easier, and cheaper to make.
Personally, I want nothing to do with low profile tires, the elimination of the side wall, also eliminates the ability of that part of the tire, to cushion the ride. So far, I have avoided buying a vehicle that has them.
