aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 16,985
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
You do realize that you can just look at the Ford site and get payloads, curb weights and trailer weight ratings, right?Tried to find the Globe and Mail article about the Ford weight versus the Chev and how the Ford was a stripped version.......but you can even see it in your link to Motor Trend.........the towing capacity of the Chev and the Dodge are 9400 and 8650 respectively ......the Ford being compared to is 5000 (so obviously not the same options for towing So Ford lighter...now look at price as tested the Ford is 46,000 the Chev is 55,000 . Again so Ford is not all optioned up. so weight lighter....but Globe and Mail had better article, I will find it showed the Ford when optioned the same was barely 90 lbs different even though Aluminum. My dog weighs that much![]()
For example, the 2015 F150 with the 2.7L engine, 145" wheelbase, Super Cab, 4x4, 3.73 gear ratios and maxed out payload and towing packages:
Max GVW: 7000#
Max Payload: 2160#
Base Curb Weight: 4703
Trailer weight: 8200#
If you spec out the same truck, but with the 3.5L EcoBoost you get:
Max GVW: 7050#
Max Payload: 2170#
Base Curb Weight: 4822
Trailer weight: 11,800#
Now, if you go with the long box or the Crew Max cab, you can get payloads over 2700# (with a base curb weight of 4930# to 4984#).
Aaron Z
