The Restore Begins
   / The Restore Begins #21
New radiators are around $200 shipped. Make sure the bolt ends are not boogered up so as they won't tighten good. If the slots are in good shape a recore may be cheaper. There are pads the radiator sits on. If you have acccess to some thick rubber sheeting it will work just as well.
Anyone have an Idea how the rear fenders come off? Are those Rivets on the bottom three connections?
   / The Restore Begins #23
They should bolt on just like the clamshell I would think to the axle. I'd have to consult the partsbook to be sure. Now on the clamshell where the hoop frame attaches at the bottom with three rivits. But n mine the fenders both to the axle. Two bolts for each side.
But those are rivets that connect to the fender mount? Need to ground these off to change fenders.
   / The Restore Begins #25
Take a cutting wheel and cut the rivits off from the inside. Then punch them out. Replace with carriage bolts to match the old rivits.
Sounds like a plan, thanks. Do you know where to get replacement Power steering hoses?
   / The Restore Begins #27
If you take your old hoses to a hydraulic shop. They can custom make the ends and put those nice quad crimps on the ends. Those hoses have some weird bends. Kinda remind me of a 66 mustang with PS I used to own.
Starting to take off the fender bolts at the Axles man are they stuck! Any Ideas to get them off? Hard to hit where their at.
   / The Restore Begins #29
Use a half inch drive with a cheater bar. In fact it might require two cheater bars. On to secure each end. I had to cut one bolt in two if you remember. Have you removed the wheel for better clearance?
Got the nut loose can.t get the bolt out. Its rusted to the axle. Took a service jack and jacked it up on the nut still stuck.
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
MISC PALLET OF SPM PUMP PARTS AND JOSES (A53843)
MISC PALLET OF SPM...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
Case 235 Tractor (A53117)
Case 235 Tractor...
