Things I do and don't like about my F-150
   / Things I do and don't like about my F-150 #31
I use mine each week. I have owned about 15 4x4 vehicles and only had one failure on a S10 Blazer. My father and BIL have had just as many with zero failures. We all use ours all the time but my father is getting guilty of not using it unless I remind him.
Chris
That is one thing I like about my SuperDuty. It has manual hubs and a manual transfer case.
   / Things I do and don't like about my F-150 #32
And my next truck will have them too!
   / Things I do and don't like about my F-150 #33
I haven't had any 4x4 issues with any of GM's---Ever...The 83 K5 had the backup to release (stupid) but that was my only ever complaint.
I only use 4x4 when I need it, not as a maintenance issue...I used to run them to 200k without issue.
   / Things I do and don't like about my F-150 #34
I have a Jeep Commander. It's full time 4wd with electronic limited slip diffs, front and rear. The diffs will go from free wheeling to full lock as needed. One of the best systems on the planet. But I wish I had a little more ground clearance and more room in the wheel wells for taller tires.
   / Things I do and don't like about my F-150 #36
Good luck. I have not seen a manual transfer case or tranny in a few years.
Chris
The plant manager who runs the foundry I work at has a new (no more then 2-3 years old) F-250 with a manual transmission, transfer case and manual hubs.
He did have to special order it as it was (apparently) deselecting options that are more or less standard equipment.
Anyway, I never buy new...an older truck works for us.
   / Things I do and don't like about my F-150 #37
My biggest gripe about my 2011 f150 is that its really more of a car than a truck when it comes to hauling or towing. I guess that's why it rides so nice when its not.
   / Things I do and don't like about my F-150 #38
Not sure what car you are using for comparison. How low is your payload? My truck doesn't even have the max payload option and it is rated to tow 11,300 lbs and 1835 payload. Haven't seen too many cars with those specs.
   / Things I do and don't like about my F-150 #39
There seems to be quite a few "Which Truck" threads on here so I'll add my $.02.
1st off-The Truck. I had a few requirements when I bought my truck last year to replace my '03 Z71 Chevy. First off, it needed to be crew cab. 2nd-it needed to have a real 6.5' bed. Other than that, the field was wide open.
The 2nd requirement excluded the GM twins(I only buy 1/2 ton for personal use), although I liked the styling of the GMC much more than the others. I opted for the Eco-Boost in the Ford, betting that I could squeeze a few extra MPG out of the turbo motor over a V-8. Hopefully the extra equipment and computer stuff will hold up.
Truck is a basic XLT package, but it has most all the options I want/need. Power windows, p-locks, cruise, a/c, 4x4, electronic rear locker, 3.55 gears (would have got 3.73 if I could have found one), Sat Radio, single-CD, cloth seats (I really like the front bench with fold down console). Price was $34K+tax, drive out a little over $36K. This was the best deal I could find.
Truck bought in '12 (as a '12 model). Currently about 12K miles, which is about 2x what I was putting on my chevy. Since I have two kids we much prefer traveling in the crew cab over our older car.
Fuel Economy and Power
Things I like about the truck-the ecoboost engine has ample power. This thing will flat out go and is smooth in everyday driving. I really like how the engine responds and it pulls trailers really well also. The non-towing mileage is OK. Right now I'm avg. about 16-17 mpg all around driving, which is about 1-2 mpg better than my old 5.3 Z-71. If you are looking to buy a truck I would say not to get the EB for the added milege but moreso for the power and torque. I have not driven a 5.0 but from what I have seen the EB gets about ~1mpg better, which is exactly what the sticker says. On the hwy the mileage can really vary depending on speed. If you can keep it at ~55 mph you can easily get 22-23 mpg. On a slow cruise at say ~45 down back country roads I have gotten as high as 26 mpg. 60-65 mph I get about ~18-19 mpg, 65-70 about 18 mpg, and anything over 70 and you're going to get 16-17 mpg tops. BTW I was hand calculating the MPG's for awhile but the numbers always came out very close to what the computer says. Also when refueling I noticed that the "Fuel Used" gauge is pretty accurate, down to a .5 gallon so I started going by the computer. BTW these numbers have all come on fairly short cruises, I have not went on many long-distance trips. Most of my medium distance trips are about 60-80 miles of hwy driving. I have taken one or two 2-3 hour trips and ended up at the 18-19 mpg mark traveling on the interstate at 60-70 mph. A few times I hit 19.9 on medium trips.
Crew Cab
Other things I like-the crew cab is really, really roomy. In my opinion this is where the Ford shines over the rest. I looked into the GM twins, Toyota, and Dodge. I didn't look at the Dodge very seriously but the crew cab room in the Ford really outshines the GM trucks and they do not offer the full-size bed. Toyota shrinks their cab to get the 6.5' bed. I believe that the Ford is the only truck that offers the same size cab regardless of bed size. Another thing that is handy is that Ford offers a re-tractable step just in front of the wheel well that you can kick out and stand on to be able to reach into the bed next to the cab. When you're done you simply kick it back in and it locks in place. This is very handy, especially since the trucks are so much taller.
No Tinted Visor on Windshield
Things I don't like: I didn't notice when I bought the truck but there is no tinted visor on the windshield. There is a part in the middle that is tinted and makes a "F-150", but the drivers and passengers side are not tinted and that really bugs me. The back windows are factory tinted, I don't understand why the front windshield is not tinted with a 6" strip like most other trucks I have seen. I plan on getting the front windows tinted soon and I'll have the window guy do the windshield also but IMO this should be a factory option.
A/C Speeds and Vents
The A/C only has 4-speed settings, and IMO, it really needs 5 speeds. There are no vents to the rear seats, and that's a shame because to get the entire cab comfy you have to blast the air from the front vents, which freezes out the front occupants while the back-seat passengers do not get enough cool air. My '03 chevy ext. cab had rear vents, I do not understand why Ford chose not to put them, especially in a vehicle with a cab this size. With the controls the jump from speed 3 to 4 is too high, I wish there was a 5th speed.
Radio
I think the radio is really under-par for a truck like this. The sound is not really all that great and the radio does not have the feature that shows the station and song like my old chevy had. It will tell you the station and song on Sirius, but not FM. This is something I really liked as you could see what you were listening too (song title/artist).
Gauges
One more minor thing-there is no battery gauge. This really bugs me. We may not really need one anymore but I didn't even realize that I didn't have one until I had owned the truck a few weeks. It has 4 gauges-fuel, oil pressure, tran temp, and engine temp. No boost gauge, and no bat temp. There is a digital tran temp on the driver display. The man. gauge is re-dundant. I wish that the drivers display (4 inch screen in the middle with fairly HD graphics) would have all the engine parameters available like battery, boost, etc. Not a real major deal, but would be nice to have.
Bed Height
One more major thing I don't like about the truck-bed height. I know that all the manuf. are doing this, but why does the bed need to be so freakin' tall? I'm 6'3" and I find it difficult to reach over into the bed and grab anything. If it weren't for the retractable steps most stuff would be out of reach. Also, since the bed is taller, the tailgate is taller and I cannot let the tail-gate down when towing my 16' flat-bed without it hitting square in the middle on my jack. My old truck tailgate would clear this by about 2", and it made it easy to get in/out of the bed. With the Ford if you drop the tail-gate the jack will hit it and you risk denting or scratching it. To me it's one of those things that looks good but is less functional. I know all the manuf. are doing this just like putting those huge wheels on but IMO give me an older trucks bed height and 16" wheels and that is much more functional.
I hope this was informing to those who are interested. Overall, I really like the truck and I would buy another. I really wish I had a chance to drive a 5.0 so I could compare it to the EB.
Nice review!
A few points about your "dislikes"
Rear vents - you would need to step up to FX4 or Lariat plus models to get rear vents in the center console pod for the rear seats
Stereo- Was an option on my '06 FX4 crew to get "Audiophile" stereo with subwoofer
May have been an option on your XLT don't know! If you would have custom built and ordered.
The big 3 have gone the way of the imports in this way that you get options ABC with base package, options ABC+DEF and options for more $$ to customize with mid grade and A-Z with top package.
Just my observations/experience
   / Things I do and don't like about my F-150 #40
Nice review!
It is an option to get the Sony system with sub but they are expensive and get poor reviews. Most agree it is better to get the base sync system and improve with aftermarket components for less money and better sound.
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
Forklift Safety Basket (A56857)
Forklift Safety...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
