I was cutting the grass and was almost done when i noticed slight vibration ,i thought one of the blades was loose so I stopped the tractor and checked the blades all was good i then lifted the hood and checked the oil it was full and checked the antifreeze it was full,looked around engine bay all looked good ,so I got back on the tractor and started the engine ,all of sudden heavy black smoke and the engine reved up to max rpm 3500rpm or more? I turned the key off, holding the key in the air not even in the ignition and the engine continued to rev . i tried to close the throtle but it was already closed, no response, i was now thinking this engine is going to blow, i now tried to loosen the fuel filter to introduce air in fuel to stop the flow ,fuel now leaking now i'm thinking fire so i tighen the filter and engine still racing, then i though i better load this engine so I put it in high gear and drive it ,this did bring the engine rpm down a bit around 3200rpm and still blowing black smoke and i notice the fuel gauge now reading about a 1/4 tank, could i be burnning that much fuel it was almost full 5 minutes ago, i could also hear knocking in engine,then after 2minutes it starts to slow down and now i see white smoke ,like when and engine blows (coolant in combustion chamber)now engine shuts off ,I get my son and wife and a friend to push it back in the garage NOT A GOOD DAY, suspect something stuck in injector pump (diesel run away)
