Think I found my duallie
   / Think I found my duallie #11
Good looking truck!
I think I read every question you posted and the answers, which kept me from having to ask the same questions...
After my last trip to Moultrie, Ga (130 miles) the wife told me I had to get serious about buying a truck and not just waiting on "the right one". I am glad I didn't listen to her...
as I really like my truck.
David from jax
   / Think I found my duallie #12
AWESOME!
I think you will like the 4.10 gearing not as agressive and rpm intensive as a 4.88 and not as fast as a 3.73. with 4.10 you can still travel on the interstate without holding up traffic, but still have ok fuel economy, and are not a few hundred rpm away from redline like a 4.88 is... yet.. still has plenty of pulling power.
I look forward to seeing more pics and hearing about your truck!
soundguy
Soundguy,
I was just wondering if you had ever considered a Gear Vendors overdrive unit for your F450. I know "most" of your driving in it is chasing down old tractors, but even then the rpm could be dropped while your in Florida's flatlands.
David from jax
   / Think I found my duallie #13
The downside to getting a Gear Vendor OD is that for the average driver there is no payback.
Most people don't drive enough to make the numbers work, you could probably buy close to a 1000 gals. of fuel for what one costs.
   / Think I found my duallie #14
Since 2009 I've been buggin' y'all on this forum about tow capacities, duallies and 4x4's.
I greatly appreciate all the helpful input, especially from Diamondpilot and Duffster.
I started wanting a Dodge:
http://www.tractorbynet.com/forums/...king-good-deal-2500-3500-a-3.html#post1670252
Then almost any diesel:
http://www.tractorbynet.com/forums/...ecommendations-links-diesel-truck-used-2.html
And got to wondering if I needed a 4x4:
http://www.tractorbynet.com/forums/trailers-transportation/225099-how-important-4-wheel-drive-8.html
I know I've seen a few "slip" thru my fingers, but rarely have any turned up close enough to me for a quick test drive.
One finally did and if the paperwork goes thru I'll be getting a 2002 Ford 350 XLT 4x4 7.3L diesel dually w 4.10 gearing to help me pull logs. Paid too much but SWMBO was getting tired and was threatening to make me buy a new truck.
Beautiful truck!!! Congrats.
   / Think I found my duallie #15
If fuel is your only consideration, maybe so. What about the reduced rpm's on the motor when running empty, and the overall engine hours that it saves? If fuel was my only concern, I wouldn't be driving a diesel p/u...in fact would drive the bowtie that is sitting in my driveway, undriven but insured...
David from jax
   / Think I found my duallie #16
Soundguy,
David from jax
i looked at it briefly, but fo rthe money and the miles I go, decided against it. also considered 4.10 gear swps too... decided against that as well..
Hijacking my own thread -
The guy I'm buying it from claims about 15 to 16 mg empty, 12? towing, 18 if his father drives it empty
BUT he replaced it w/ a new F450 diesel w/ DEF and has been hauling heavy loads (33,000 GCVWR) and only getting 6mpg, not broken in yet, and about 10 around town.
Are the older 450's that bad?
   / Think I found my duallie #18
The numbers on the F-350 sound about right. The F-450 is also about right. You have to remember it has different wheels and way deeper gears. The old 7.3L or even a 6.0L F-450 will get a little better but not much. Maybe 12mpg.
Chris
   / Think I found my duallie #19
Those are the exact numbers I have been getting, but I don't baby it, and I haven't hauled any HEAVY LOADS, yet. A few thousand pounds on a 3800 pound trailer.
David from jax
Mine is a 2000 F350 7.3 six speed
Well it's been a month now and I've driven it to Mississippi towing a minivan at highway speeds and got 14+mpg.
I've gotten it stuck on wet leaves and clay and had to put it in 4 wheel drive and it walked out.
I've piled the bed with furniture, plywood, and various and sundry things.
I just feel underutilized if I'm not hauling something.
It fit's just fine in my RV shed with the pallet racking. It works great as something to climb on to get to the higher shelves. But I could probably find a cheaper ladder.
Water Pump (A57454)
Water Pump (A57454)
Auger Skid Steer Attachment (A56857)
Auger Skid Steer...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
