Thinking assistance, please!
/ Thinking assistance, please! #1
dihub07
Ohio
Hello, Folks!
I've been reading threads for months (not to mention literature and other websites). I've got JD and Cub Cadet dealers within 5 miles, a NH and Kubota dealer within 15 miles, and MR and IH dealers within 30. I understand the importance of a good dealer relationship.
My stumbling block is, I can't decide what size tractor is appropriate . . . hence, my request for your aid!
We've a 4 acre lawn, 2/3 which is undeveloped (but will be developed into lawn, more garden than what we already have, and landscaping); though 10,000 (100X100) square feet of the undeveloped part is garden. More garden is definitely an option. (Neighbor has a JD 4100 with a tiller so a tiller is definitley nearby). With the garden, we haul a "nice" amount of horse manure from the neighbors (getting tired of doing it by wheel barrow and a trailer behind a JD 318). Also, living in NW Ohio, snow moving capacity will come in handy. A 60" MM mower is preferred by my honey. The driveway is gravel so considered a blade or box blade for driveway work (stone and snow)
What I've looked at:
JD 2320 and Kubota BX2660 . . . too small??
Cub Cadet Sc2400 (too small??) and EX 3200 (too big???).
Used NH TC29.
MF 2300 and 1533\
I'm not concerned about speed or power for mowing . . . any of these units will handle the mowing. My concerns are the wear and tear over time with the tilling and efficiency in bucket work (don't want to be over-powered but don't want to be frustrated with too many trips). At times, I've thought the neighbor's 4100 was a bit under-powered in the lifting department.
Any thoughts will be helpful.
Thanks!!
/ Thinking assistance, please! #2
B7800 at 30 hp. However the B3030 at 30 hp with the cab will be very nice in the winters with a snow blower.
I'd look at something in the 26 - 30 hp range. I personally don't like to overwork a machine because my expectations outweigh a smaller machine's capabilities.
Just my opinion, regardless of the work.
That 4100 is a 19 hp machine. I can see where it may be a bit underpowered for ease of handling the implements.
/ Thinking assistance, please! #3
Since you said "Any thoughts", I'll chime in, even though I'm still a rookie.
To me you want a SCUT at a minmum, based on the acreage. I think most will still want to know about the undeveloped portion - flat or hilly, open or wooded.
Rule of thumb - SCUT will do whatever you need - just slower
FEL effeciency will be based more on capacity not power - SCUT will handle a filled bucket just fine - but they are smaller buckets. I think tiller work will be no impact as long as the tiller is matched to the tractor
I am in a similar situation, but undeveloped area is all woods and whole property is steep hills. I've cleared 300 feet of woods for a "driveway" to a site for my future pole barn. After clearing the site, have moved four full truckloads of fill, 300 feet, to the site with the bucket on the BX - very tedious, but safest and most effecient given my hills. Now that driveway is clear and level driver said he would take his truck all the way in next time which should speed things up.
If you go bigger you won't be disappointed (unless there are tight areas) - but don't think I would go smaller....
Sorry for the lack of clarity . . . "under-developed" means nothing really has been done to that portion of the yard. It is flat and open - bascially, a weed field
/ Thinking assistance, please! #5
If lifting is a concern then that's a feature you need to look at. Front loader and 3 pt. lift capacities.
Here's my 2 cents.
I have a 26HP HST Mahindra 2615HST. It serves all my purposes. 3 pt. lift cap. is 1653 lb. at 24" behind lift point and loader is about 1050 lb lift capacity to full height (to pivot points) and 2172 lb breakaway capacity @ pivot points. Both ratings are very conservative in my estimation. That's probably about what most 26 HP tractors will do. If you need more you may have to step up to a 30HP. I looked at several other equal HP brands before buying mine and felt the frame and construction of Mahindra was much stronger and beefier looking. Plus I heard a lot of good things about the Mitsubishi diesel mine has. I've had mine about 4 1/2 years now and have about 300 hours.
/ Thinking assistance, please! #6
An answer to what size is right needs to include consideration of how much time you want to spend doing the tasks you have described. A subcut (BX, 2305, GC, etc.) will do all the tasks described. A large CUT will accomplish the same tasks faster, because it will use significantly larger implements. For mostly lawn work, lighter is generally preferred. For ground engaging tasks, more weight is your friend. I would prioritize my tasks, the one which will be done most getting the most weight in the decision. For tasks that will be done once, such as leveling for putting in more lawn, you can consider renting or hiring done any tasks which would overwhelm a tractor that you would need long term. The long term needs to be you primary consideration; you wouldn't want an M59 to mow with, for instance, once the dirt moving is done.
You need to also talk to your local dealers. They have (or should have) experience in sizing tractors to needs. And you need to sit on the models you are interested in, and see which one fits you best. While you are about it, nose around the parts and service areas of each dealer, see which dealer fits you best as well - most consider the dealer to be an important part of your selection, as you will be relying on them for parts, service, and advice.
Good luck in your search, and post back often to let us know how it's going.
/ Thinking assistance, please! #7
I have a JD 2320 and do all that you want. Snow depends on how much snow you're talking about. I just use my loader and box blade, but a rear blade would be faster in my snow which is a max of 6 inches at a time here. If you have tons of snow you probably will want a blower and the type and size of blower can dictate the size of tractor. Just search snow removal under each mfgs forum here and you'll see all the pros and cons of each. If you have woods or steep hills, bigger is not better though.
/ Thinking assistance, please! #8
I have to disagree just a bit as I feel ground clearance is important in the woods.
/ Thinking assistance, please! #9
Dihiub07,
I am no expert, but with what you listed for tasks I would think you are going to want a 26 HP machine at the minimum, however I would recommend a 30 HP machine if it is in your budget. Also, you can never be over powered with a tractor, but you can end up underpowered:D! I am slightly biased as I bought a 30 HP Kubota B3030HSDC two years ago when I purchased. At first I was looking at 23/24 HP machines, but I opted to go bigger and I am glad I did. I have a buddy that just bought a Kubota BX24 last fall and he already wishes he would have went bigger. Not that the BX24 won't do what he wants to do, it is just going to take a little longer and at times could use more fel lift capacity. The initial purchase of my B3030 was to put in a 2 acre yard, there was lots of digging up and hauling of large rocks, lots of dirt moving, and a lot of dragging, along with some skidding of trees. The tractor performed great for me in all the tasks. Anyway, I would look around 30 HP for what you want to do. AS for the brand, I prefer Orange, but all the brands you mentioned produce good tractors. - my 2 cents.
/ Thinking assistance, please! #10
I am not sure of your snow amount-- BUT I would reccomend a cab..
Where I live in Western NC, we don't get enough snow to worry about it..
and if it changed, I buy an aftermarket cab..
the cub 3200 is nice, but unless there are alot of favorable posts I would not go after that tractor.. when I was looking last year a lot of folks reccomended that it sit and get more proven especially for a first time purchase...
anyway.. I would reccomend that you test drive as many as you can.
Later,
J
/ Thinking assistance, please! #11
I own a Kubota BX2350, and from what you describe, it might be a little to small. It will do what you want, just take more time. The big thing, is how much money do you want to spend. I have about $15000 in mine. Thats for a 60" mmm, FEL, rear blade, mulch kit and some other small items. I bought a trailer to haul it with, thats another $2500, but I didn't really have to have a trailer. I guess what I'm saying, it can add up in a hurry in terms of cost. A B series might be a little better from what you describe. I can't believe how much I have used mine, and am still kicking myself for not buying one sooner. If you can afford it, you won't regret getting a small tractor. Knowing what I know now, I would get used, you just have to get over the fact that they aren't all shiny. If you have someone you know that has some knowledge of tractors, that would help you find a used one.
/ Thinking assistance, please! #12
I see you are from ohio, have 4 acres and not worried about power and speed. BX is your ticket. It can handle a 4'-5' bush hog, 42"-50" tiller, a 60" MMM or RFM. Since you say you have feild withg weeds, chances are you may not need a bush hog. If you wait till spring when everything is smooshed down from the snow and then mow it with your MMM or RFM, you will be fine. If you think there will be rocks, small trees to to clear, then you will need a 4' foot bush hog at least to clear the lot for the first time. you haven't mentioned if you need to do trenching or ditch clearing, then you probably only need a BX2350 go go the next one up to B series for more power, lifting capacity.
/ Thinking assistance, please! #13
How about a Kioti CK 20? Should have the capabilities you are looking for, strong loader, etc.
I have 3 acres, tons of rocks and stumps. I have a Kioti 30 HP machine and does all i need.
The one thing I find different from the 20's HP to the 30's HP machines is size, particularly the ability to load trucks and the like.
There is a substantial difference in capabilities.
With tractors, rarely do you see people going down in size, more frequent they go up.
Joel
/ Thinking assistance, please! #14
I'd say the BX will do what you want. You don't need horse power nor, from what I read, extra ground clearance. The only challenge for a BX I can see is the amount lawn you'll be mowing. If you need more of anything it isn't HP or tractor. A real lawnmower would be better like a ZTR to get that much lawn mowed in a shorter period of time.
/ Thinking assistance, please! #15
One thing to consider...which has not been mentioned.....those 30 HP tractors may take a toll on your lawn when mowing....especially with non-turf tires and 4wd. So....maybe a SCUT is what you want if your trying to protect your lawn too? In any event...consider your tire choices. my .02
/ Thinking assistance, please! #16
I have to agree with RadarTech, go out and do all the test drives you can. A lot of dealers will drop off a tractor at your house for a "free" trial on your property. They are all basically excellent for what most people need them for so don't get into the color war. Have fun. Oh BTW did I mention a certain "RED" :rolleyes:MF 2310 TLB that I happen to be partial to?
/ Thinking assistance, please! #17
Joel
I didn't go down in size but i did add 2 smaller tractors.
I handle that with 2 BXs and 2 operators.
One with a 60 '' and another with a 48'' MMM.
One thing to consider...which has not been mentioned.....those 30 HP tractors may take a toll on your lawn when mowing....especially with non-turf tires and 4wd. *So....maybe a SCUT is what you want if your trying to protect your lawn too? In any event...consider your tire choices. my .02
*Yep R1s are not an issue on S-cuts like they are on the other tractors.
*Oh BTW did I mention a certain "RED" :rolleyes:MF 2310 TLB that I happen to be partial to?
*Just like i didn't mention an orange BX23 TLB.
/ Thinking assistance, please! #18
Sounds like you have a color choice to make!
Several people have several very good points that I've read. I'm curious if you have just the 4 acres (or more?), any woods, and hills/slopes? All factors when picking size/HP of tractor.
You're in a very fortunate position/location to have several dealers close by, and I second the motion of trying everything. All the machines you mentioned are good.
I'm a "yellow" guy, so I know what the sizes/HP for Cub Cadet are, but not real familiar with the rest.
I use my 23HP for mowing/blowing/blading....it weighs in at 1400 lbs. (tractor alone) My 28 HP has a loader and setup for mowing, which I would still do (1900lb tractor) My 32 HP I would not mow with, just too big and heavy. I would fall in with the other opinions that 26-30 HP would be your best bet....and keep an eye on the weight. Mowing a wet lawn with a 1 ton+ tractor may have consequences!
I also have and like very much a front blade for snow removal. Most newer tractors have quik-attach loaders, so the front blade can be installed quickly.
Take your time and check them all out...that's half the fun!
Thanks for all the thoughts :D
Between the green and the orange, I'm narrowed down to the JD 2320 and the Kubota B2620.
Attractive though, is the MF 1523 and 1528 (admittedly, part of that attractiveness is the 60 month financing).
Kubota certainly stresses "everything made by one manufacturer", the incremental/gradient flow on the 3-point, and their price is better than JD. Against the MF is the distance from the dealer (K and JD much closer), but the MF has some nice features the other two do not (telescoping arms on the 3-point, the hand and foot throttle.
Any comparison thoughts on these colors and models?
Thanks!
/ Thinking assistance, please! #20
I have a Kubota L3000 with 4WD and FEL that I bought new about 6 years ago. We have 11 acres of mixed woods and pasture and put a little over 100 hours a year on the tractor. It handles a 5 foot mower and 5 foot tiller with no problem. After having a slightly smaller 2wd tractor with no FEL this one make a big difference. I wish I would of bought one like this 5 years earlier when I was still clearing brush and trees. In my case it it just the right size.
Down here on the gulf coast snow is never an issue but weeks of heavy rain is. The 4wd was worth the extra money and would go with it again if ever I bought another.
In the 6 years it has been problem free.
2018 FORD F-150 (A67714)
2018 FORD F-150...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
ITS 16 Pipe Squeezer (A68842)
ITS 16 Pipe...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2001 STERLING LT7500 SERIES (A67714)
2001 STERLING...
PAIR OF TRACTOR TIRES AND RIMS (A67714)
PAIR OF TRACTOR...
