This might be a stupid question
   / This might be a stupid question #11
My 1999 B2710 HST tractor came with the block of wood mentioned above, but I never used it. Of course my tractor was stored inside and didn't go very long between usages.
But in the early '50s, we had a 1940 John Deere L that was parked outdoors behind the barn when not in use, and sometimes sat unused for quite some time. So sometimes when we went to use it, the clutch would be firmly stuck. I don't think OSHA would approve our remedy.:D The tractor was a 2 cylinder gasoline, hand cranked engine, 3 speed transmission. Of course we cranked and started it in neutral, then if the clutch was stuck, we could not get it into gear, so we'd let it warm up in neutral so it start again very easily, shut it down, put the gear shift in "low" or 1st gear, yank on the crank in the front end to start it, jump out of the way so it didn't run over us, then climb on from the back as it went by, open the throttle wide open while standing as hard as possible on both the clutch pedal and the brake pedals. That always popped the clutch loose and all was well until we left it unused again for extended periods of time.
   / This might be a stupid question #12
My 2920 came with a small block of wood that has a sticker on that says basiclly if you are storing your tractor for long periods of time to depress the clutch and wedge it between the pedal and the underside of the floor board so it keeps the pedal in a depressed mode. Looks like you have a fancy button instead of a piece of wood. My guess is it must be better on the clutch to store it that way.
Same here on my B3200 (block of wood)
   / This might be a stupid question #13
Another reason may be the long trip from the factory and the salt spray. Just a thought. David.............
   / This might be a stupid question #14
In 1974 I had one of the earlier Kubota tractors in my landscaping business. Used it almost every day till about December. Let it sit for two weeks. Clutch stuck. Breaking a tractor in two in the middle of winter is no fun.
That same tractor also had an engine sieze due to someone not cleaning the oilbath air filter in a timely manner. Kubota bought the engine back after replacing it to study the ill effects of abuse. Just bought a '09 B3200, nice tractor! I put the block in the pedal after every days use.
   / This might be a stupid question #15
Maybe I am getting to deep into this and also showing my age.
Thank you for educating me.
Joe
Asking lots of questions and being curious about things does not show your age, it shows your youth.
   / This might be a stupid question #16
We had a late 80's MF. On that tractor, if we didn't lock the clutch out after every use, eventually, the gears would end up grinding when shifting. After splitting the tractor twice, we just got into the habbit of doing it all the time. It was much easier doing it when we got off for the day than splitting the tractor :(
   / This might be a stupid question #17
I have a New Holland TC-29 and it only sat idle for a week at a time and had no provision to lock the clutch down, nor did the owners manual address the issue but one day I started the tractor and could not get it into gear. I called the NH dealer and he said the clutch was stuck and they would have to break the tractor to fix it and it would cost about $2,200.00....So I called a local independant farm tractor dealer that sold mostly used tractors that I have known for a long time and he came and got the tractor and fixed it and brought it back the next day - charged me $100.00 for the pick up and delivery and the fix...He said to keep a block of wood wedged so it kept the clutch depressed whenever I was not using it..even if just overnight...Trust me I lock that clutch pedal down at the end of each use. I just post this to pass on what could have been a very costly error...it may never happen to you but what if it did and it sure does not take long to insert that wood..better safe than sorry.
   / This might be a stupid question #18
The same problem can happen with brake drums on older vehicles and trailers. I discovered not to store my Suzuki Sierra (Samurai) with the hand brake on. The wear pads will stick to the drum and can even seperate from the metal shoe. I use it for beach drives and launching the boat so admitedly the conditions are pretty harsh.
   / This might be a stupid question #19
Out of curiousity... I know its not a kubota but when i owned my 40's 8n, i never ran into this issue. The tractor would be left out in the yard with out use for up to a month too, any season. Was this a common issue of these parts sticking?
   / This might be a stupid question #20
Our old Farmalls never had this problem either. Sat outside all winter, never an issue. I suspect it has to do with the clutch lining material. Just my uneducated guess
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
