This Was NOT An Accident
   / This Was NOT An Accident #31
Have you tried boring the holes in the stump and filling with diesel fuel until it is soaked up? You can bore a hole sideways, or 45 degree angle toward the center. Then set some charcoal at the bottom holes and light. After burning good, place a fan or blower on the charcoal and stump , and the stump will burn inward and up. The fan or blower will add extra oxygen to the fire. Sort of like a forge.
Dan, I have successfully burnt out a couple of old well rotted stumps that were a few years old by just dousing them with diesel fuel and allowing it to seep and soak in for a couple hours prior to lighting it up with some mineral spirits.
It takes a long time for it to slowly smolder underground down the cambrium into the roots so is kinda dangerous because the root ball burns slowly for so long.
All I really need is to get it down below ground level a little so I can simply put a load of sand over it for cover and filler.
J.J., one of those 110 mph leaf blowers will fan one heck of a fire for ya like you described! :D
11' CONTAINER (A52706)
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
TANK MANIFOLD (A58214)
2022 Kubota Z422-54 Zero Turn Mower (A56436)
2022 Kubota...
