Thoughts on PTO weight attachment
   / Thoughts on PTO weight attachment #11
As a tractor newbie it is interesting to see the variety of solutions to common needs. I really like the receiver suitcase weight arrangement. Integrate that into a quick hitch and it's a winner for convenience (but maybe not cost). Find a way to use it in the front or rear and it would solve a multitude of balancing quandaries.
   / Thoughts on PTO weight attachment #12
One thing to consider is how much weigh is a "receiver" actually going to handle safely.... I am coming from point of stability (tilt) I think a 3PH would be more stable, as time goes by the receiver (actual box) may become bent and distorted and become sloppy and there for become hazard to tractor/work operation/operator ...
I think even with my small tractor and only anticipation a 600 pound (or so) ballast I will stay with 3PH (quick hitch) concept...
Dale
   / Thoughts on PTO weight attachment #13
I have a cheap decently made Titan ballast box with 4x4x8 inch cement blocks, I can remove weight quickly or add weight quickly. The box is 100lbs empty and each block weights 25lbs and I can put 10 in the box if I need to, I use 8 block pretty much all of the time. With no QH the box is fairly close to the back of the tractor and doesn't impede me moving close to things..
   / Thoughts on PTO weight attachment #14
So I bought a PTO mount trailer hitch receiver. It seem that it could also be a good and fairly simple way to add weight by just buying a 2" hitch
and putting weight on it.....for example just build a box around one and fill the box with concrete and a little rebar. Then just put it into the hitch receiver when I want the ballast on the back. Think this would work..???
How are you going to pick it up and slide it into the receiver?
How about adding a weight bracket like this?: Cat. 1 Sub-Compact Tractor Hitch Receiver & Weight Bracket for 3 Pt Hitch Green | eBay
I have their Transformer hitch, very strong and versatile: Transformer - OMNI Mfg LLC
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
UNUSED FUTURE HWG44 44" HYD HOLLOW WOOD GRABBER (A57193)
UNUSED FUTURE...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
flooring (A55758)
flooring (A55758)
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
Kubota 8" Excavator Bucket (A56469)
Kubota 8"...
