Thoughts on this tractor?
   / Thoughts on this tractor? #11
A lot of people will recommend 4wd regardless of use. You really need to determine your needs and what your budget is. I've got two tractors one is a JD5103 2wd with FEL. Does everything I ask it to do. I also have an older PK 14HP with FEL. For it's size it works very well also. With it I do have to keep the front tires inflated more than the other but with it I can use the FEL ok. Best thing I could say is try it out and see if the owner will let you move a couple of mounds of dirt to see how it handles. As to the Branson I've done some reading on it and it seems to be capable machine. Size for size a bit lighter than an equivilant sized JD. Dealer support is most important with any brand.
Good luck
   / Thoughts on this tractor? #12
Spend some time reading in the Branson's section... I would guess you would not abuse the machine and it would out last you... but it depends on what the other owner did ;) It's a BIG tractor... a work horse... sometimes they can be too big. Do you have trees that you have to mow around? I am guessing that this is a gear tractor instead of HST... if it wide open mowing, it will work but if you have to shift gears a bunch, it gets tiring...
   / Thoughts on this tractor? #13
Knowing where you are located might help for several reasons:
*The prices of used tractors vary with different parts of the country.
*Some members can/will recommend a particular dealer to use/avoid - and this advise can be very useful.
*Different areas also have their own issues. "Hilly" can describe land in Florida as well as Iowa, but these two places are quite different. In Florida, you will not need a snow plow but Iowa does not have near as many swamps.
   / Thoughts on this tractor? #14
I would not be scared of the Branson. I own a 5530C and my neighbor owns a 4720i ... the only parts I have needed was an a/c pulley, filters and the dealer had them available.
Nice heavy powerfull tractors ...
I live in Maryland Suburbs....snow = yes, though not terrible. Hills = not really at least on my property.
Closest dealer is accross state line in PA about 40 miles away...Deutz Boys.
   / Thoughts on this tractor? #16
That looks like a good deal on the Branson. Go check it out. If you like it....
   / Thoughts on this tractor? #17
My uncle has a Branson about the same size as that one, but with a cab, and swears by it. He works it hard in logging and snow removal and has had no problems that I'm aware of. And the price seems pretty good too.
Moe
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
Informational Lot - Financing (A53473)
Informational Lot...
2008 PETERBILT 367 HOT OIL UNIT (A53843)
2008 PETERBILT 367...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
434669 (A48836)
434669 (A48836)
1996 JCB 506B Telehandler (A53473)
1996 JCB 506B...
