thumb for Kubota B21 w BT751 hoe
   / thumb for Kubota B21 w BT751 hoe
If you do straight linkage only thing to fabricate is the base cyl mount which is easy with the tools you have.
For you is easy . . . to misquote Senor Wences . . .
Actually, I may have a metal working lathe. Long story of hand me downs, but I think I have it stored in the barn. Haven't thought about it in a while.
If you had to do it over again, would you weld it on instead of using all those bolts? Or some similar load spreading deal?
   / thumb for Kubota B21 w BT751 hoe #12
I would do the same. The girdle is kinda ugly but it cannot bend the stick, loosen or shift anywhere. At the time there was a thread or two about guys bending their sticks with weld on thumbs. I decided to be super cautious. Maybe a long (12-14") doubler plate welded to the bottom of the stick and under the cyl mount would work fine though.
   / thumb for Kubota B21 w BT751 hoe #13
Does anyone have pictures of the Titan bolt on thumb attached to their bt751?
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
1992 Trail-Et (A57148)
2001 Kubota KX61-2 (A55272)
2001 Kubota KX61-2...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
