Tie rod boots
   / Tie rod boots #21
I have been turning wrenches for a living for closer to 50 years than I care to think about and have never used a fork or press on tie rod ends and never damaged one. Back when I was a pup a mechanic I learned most of it from (and still did not learn all he knew) taught me the importance of backing up the eye with a second hammer to increase the shock. Besides like has been said, since they were just replaced they will more than likely pop loose easily and nothing to align. Even if there were aligning a tractor is child's play.
Sorry John, I was typing while you were. :)
   / Tie rod boots #22
So OP is supposed to go buy a widget tool to remove two tierods? What's that tool cost?
Have you ever saw a Professional Mechanic remove a tierod? :)
Hey... isn't it an unwritten rule that you never talk a guy out a tool purchase? :laughing:
   / Tie rod boots #25
YouTube キ Tony Fanelli
13:18
Kubota BX Series Inner Tie Rod Boot Replacement - BX25 / BX22
21 oct. 2016
Video on bx
   / Tie rod boots #27
Good video thanks for posting. Went to order them online and looks like he is out of business. Putting the metal rings back on the boots is a pain in the arse. I like the zip tie idea. Next time I will use them.
   / Tie rod boots #28
Only good quality zip tie, if possible with metal tab, or, litle cv boots clamp you can find at the local autoparts, adustable and you can tight with a simple wire cutter plier.
   / Tie rod boots #29
Yep, I am well versed in zip ties. My company makes a speciality version that works well in downhole (oil and gas) operations.
   / Tie rod boots #30
Got one today at Harbor Freight. $9.99 minus 20%, plus got a free flashlight! :thumbsup:
Cool. Give us a report on how well it works.
60" X 39" TRAILER TAILGATES (A54756)
60" X 39" TRAILER...
2009 JOHN DEERE 544K WHEEL LOADER (A52705)
2009 JOHN DEERE...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A55758)
2004 Fleetwood...
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
