tiller for bx2200
   / tiller for bx2200 #11
jcpwrsprt said:
I run a KKII 48" gear drive on the BX2350 which is comparible to your 2200. No problems to report, works fantastic. The 2200 should have no problem with a 48"-50" Tiller.
Where are the ag tires for this ground engaging work?
I use the front blade to counter balance my tiller.
   / tiller for bx2200
local kubota dealer 4' bushhog tiller 1500.00
32" 1175.00
trac supply king kutter 48" 1349.00
agri supply 48" delevered 1257.95
maybe i can figure a way to make the one from agri supply fit
my trailer.
   / tiller for bx2200 #13
LB -- I have loaded R4's for the BX but have found they are not needed in most cases, so I have been using the turfs this year with minimal issues.
The suitcase weights work well, and make the setup more maneuverable.;)
   / tiller for bx2200 #14
jcpwrsprt said:
LB --
I have a couple of suitcase weights for my CC GT2554 that I tried to hook on the front of my BX1500 but they wouldn't clear the gril and the plate they hook on.
I may have to bolt another bracket on the plade to hang the weights on.
I thought the weights might come in hand when I'm using other 3 point attachments with this tractor
   / tiller for bx2200 #15
I've got the RS1200 Yanmar 48" on my BX2200 and it powers it now problem. I usually run it at 1/3-1/2 throttle. A 50" would be fine too. I don't have filled tires, just the turf's and they work fine for any of the tilling or plowing that I've done with it. Most of the time I don't even bother with front suitcase weights that I have. Even in 2wd it hardly ever spins a tire when tilling.
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
Redneck Predator 360 Hunting Blind (A50515)
Redneck Predator...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
