Tiller Tiller Oil Change - Confused - GTC 52-2 - BX24
   / Tiller Oil Change - Confused - GTC 52-2 - BX24 #11
Why change the oil at all? It is not like it is motor oil that is exposed to high heat and it basically just lubes large gears so there is nothing delicate or precision engineered in there. Draining the oil will not remove any metal filings etc nor will it remove the goop unless you flush it out with diesel three or four times. Quite a task. I'd treat it like a bush hog gearbox....who in their right mind does anything other than make sure there is enough oil in those things? I'm sure there are many that are twenty five years old and going strong without an oil change.
CATERPILLAR 420 LOADER BACKHOE (A52707)
CATERPILLAR 420...
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
2017 Bobcat T770 Compact Track Loader (A55314)
2017 Bobcat T770...
