Timbren rear suspension system ??
   / Timbren rear suspension system ?? #31
I might have missed it, but I don't recall anyone mentioning Sumo Springs. The best of both worlds. Something that replaces the bump stops, is a plug and play and forget thing like Timbrens, but have a similar ride and effect as air bags. I recently ordered up a set to Sumo's for my 2500. Check them out and see if they might be a viable option.
SumoSprings - YouTube
Actually I like my Timbrens I installed,they ride nice unloaded and serve my purpose when hauling my trailer.To each his own.
   / Timbren rear suspension system ?? #33
It was an easy choice for me. Sumo with a 1 year warranty or Timbren with a lifetime warranty...
-R
   / Timbren rear suspension system ?? #34
As I stated in the other post you made regarding the warranty, warranty does not imply a inferior product. Unless you can show a pattern of failures in the Sumo Spring product your comment is just short of worthless. My commercial trucks all have 1 yr / 100,000 mile warranties from the manufacturer, but I typically take them over 1 million miles and only repairs are normal wear and tear stuff that isn't covered by the warranty to begin with. There are many products that have exceptional warranties that I would not consider using simply because they don't do the job I want done.
Perspective is everything. Paul Gibson was at both Air Lift and Firestone for over 40 years as a project manager. He had tried to get both Air Lift and Firestone to do some R&D on something like the closed cell polyurethane foam concept for years, to no avail. When he found out SuperSprings was doing the SumoSpring thing and using closed cell polyurethane to get the same effect as an air bag without the issues he jumped ship and became project manager for them. This is one of the primary reasons I chose the SumoSpring option recently. Not like this is some sort of goofy idea that someone cooked up in a garage somewhere. it has been used in Europe and Africa specifically for many years. That, and unlike the Timbrens, the Sumo's reside directly on the axle all the time just like air bags, loaded or unloaded. There is no gap that could cause a suspension jolt. You get immediate effect just like an air bag and it is progressive in resistance just like an air bag as it is collapsed.
And bore a 1.5" hole thru a Timbren or an air bag and see if they still work as well as a Sumo that has had that done to it. That was one of the tests they used to make sure that the product works under extreme conditions.
Warranties are marketing gimmicks in many cases. No manufacturer is even required to offer a warranty all all per the Federal Trade Commission.
Sorry you feel other opinions are worthless except YOURS..You know what that say about opinions they are like A-holes.Everyone has one.
   / Timbren rear suspension system ?? #36
No, don't try to play that liberal, cry baby stuff and inject words into what I stated. I never dissed any other alternative product and said that it was crap, I was purely holding up the one I was talking about. There is a place for all options. It all depends on the needs and the cost benefit ratio involved. What I was purely stating was the fact of the Sumo's and Paul Gibson who was deeply involved in Air Lift and Firestone air bag systems deciding that the technology that SuperSprings is using is a viable solution and fits a great middle ground between timbren and full air bags with the benefits of each while avoiding some of the negatives of each. And Warranties are indeed marketing tools to convince consumers to buy products. There is little correlation between a warranty length of time and a product reliability.
Laffin,take it easy my friend you are the one who stated(posts #31 & 34) "just short of worthless"plus "forget get things like Timbrens" funny that statement not is dissing other products?Oh,don't forget your post#25 in this thread how timbrens "only make it worse" Some extended research on your part on the sumo & timbrens on the RVnet.com website might be benficial.Both are well liked by the towing community.As far a liberal comment leave that political crap on the sidelines it serves NO purpose.(PS)I tow in US not Europe or Africa I could care less about those 2 countries.H,mm that must be the Trump side of me coming out,laffin.
   / Timbren rear suspension system ?? #38
Yes, I did say the opinion was short of worthless, mainly because it was off the cuff and not backed up with any empirical data to support it. There was no evidence or pointing to such to show that failure rates for Sumo's were an issue that the warranty was not sufficient for the product.
And, the warranty being espoused in those posts as a negative for the Sumo's was in error. It is not 1 year, but 3 years. Look on their site.
You have the "forget things like timbrens" out of context. You are in error. Go back and look what I said..... "is a plug and play and forget thing like Timbrens" My comment was simply stating the Sumo's are comparable to Timbrens in that they can be installed and require no further maintenance. You know... Plug, Play, and Forget. That is actually a supportive comment as opposed to a negative one regarding a feature of Timbrens.
Regarding the Timbrens only make it worse comment... sure I said it and stand by it. But again, context is everything. I was stating that regular springs are so old school, and they are, compared to air suspension systems when it comes to hauling and towing. And Timbrens are no help in that regard. They just mask a problem. Unfortunately, anything we put on a spring suspension is going to mask the problem. The OEM's should be offering total air ride suspension options for their pickups as the heavy OEM's do for commercial trucks. Then we wouldn't be wasting time discussing any of this.
So your post is without merit. I still have not dissed any other product and you cannot prove from any post that I have. I have only made supportive comments about the Sumo product. At least try to be honest in what you are attempting to do. You are not doing yourself or your arguments any favors.
I always take it easy, or any way I can take it. And the liberal comment, yeah, you are doing what many in the media do.... pick and choose what is said, reorganize it to fit what you want it to say, and then try to beat someone over the head with it and put them on the defensive. It is sad our society has sunk to this level across the spectrum and is really picking up on this tactic in forums that are not even political in nature.
   / Timbren rear suspension system ?? #39
I went with Timbren because of the warranty.
-R
Nice try with the DEFLECTION post.Hey its your story go with it.My dad taught me at a early age never argue to long with idiots they will bring you down and try to beat you with experience.You win,laffin..
2013 Hyundai Veloster Hatchback (A56859)
2013 Hyundai...
24" X 32" X 60" METAL ROD CABINET (A58374)
24" X 32" X 60"...
WATER TRAILER (A58214)
(3) HAND SAWS (A58374)
2322 (A58376)
2322 (A58376)
2022 Deere 325G (A57148)
2022 Deere 325G...
