SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,359
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Relax. Slow down a bit and work for a while in experimental mode with what you have.Things are a chore because I have to make time to go up there. Get things ready, try to work, and put things away so nothing gets stolen. All the while someone is waiting for me to do something someplace else.
I NEVER have time to do what I want to do or need to do. Always rushed. Maybe things will be better when we move and I am there all the time.
A box blade isn't going to smooth out the really bad roughs areas... Gonna take a disc, harrow, some better dirt than the stuff that is there, boxblade at the end. Again, something I just have not been able to get to or the disc and harrow to do it.
... 1st Set up. How much air pressure is in your tires and what kind are they? From the bumpiness you mention I fear you have Industrial[R4] or turfs. And they are too hard. With loader the fronts need to be pretty hard [30psi would be reasonable] but the rears should be kinda soft, maybe 15PSI. AND they should be carrying some real weight - esp when you use the loader to give you stability and traction.
...2nd practice. You mention stalling. Use your lowest gear and mid rpm setting and there should be no way to stall it. Push the lip of the bucket angled slightly into the ground. The tractor should move a little as the edge cuts deeper until it wont push. Stay off the clutch. Let it spin. Use curl to wiggle the bucket angle. Youll make progress. If the ground is hard youll shave it up. If soft you may dig right in and have to curl out a chunk. Get used to the interplay of forces. Be sure you have WEIGHT on the back before you start lifting and carrying stuf -- you really need an implement as counterweight in addition to liquid tire ballast.
With a little time and thoughtful experience youll figure out whats needed.
larry
