Tire Ballast--again. Sorry.
   / Tire Ballast--again. Sorry. #11
There's a chart at this Firestone site that'll tell you how many gallons per tire for the size you have.
http://www.firestoneag.com/tiredata/info/info_hydro_2.asp
When I filled the 11.2x38 tires on my H (36 gallons filled to the top of the rim, about 300 lbs per tire if pure water) I started by putting six gallons of low-tox antifreeze. That'll protect against a hard freeze into the teens, good enough for around here. I don't play tractor when it's freezing.
I used a two gallon pump up sprayer. With the spray nozzle off the end of the wand was a good enough fit against the valve stem (core removed) that I didn't spill any. Then used a connector from the auto parts store to finish filling with the hose.
Wm
I edit-ted to remove a file I attached that showed freeze protection at lower antifreeze ratios. It didn't show up legibly.
   / Tire Ballast--again. Sorry. #12
Wm
   / Tire Ballast--again. Sorry. #13
You mix the alcohol with water. I can't for the life of me remember the ratio. It seems like it was one gallon of alcohol to 3 gallons of water, but I'm not sure. It's been to long.
   / Tire Ballast--again. Sorry. #14
Jerry, is that ratio (or something similar) sufficient to prevent rust or just function as an antifreeze?
Willfick, are your tires tubeless and if so, have there been rust problems?
Update: Here is a reply from the site I linked to in the original post. I may seriously give this a try. It seems perfect.
The reply:
Dear George:
Here is a link to the product that is perfect for what you describe.
http://www.corrosionvci.com/corrosion/proddetail.php?prod=VCI-841-Powder
Use is 1/2 of 1 percent up to 1 percent by weight of the volume of water. It is safe for yellow metal valves etc. and for use on rubber and other synthetic materials. It is compatible with anti-freeze additives etc.
Use is 2 to 4 pounds per 50 gallons of water. It is available in quantities as little as 5 pounds and up.
Rick Kozuch
www.corrosionvci.com kpr@corrosionvci.com www.corrosionvci.com/blog
KPR ADCOR INC. 'We Stop Rust!' TM
Toll Free: 1-866-577-2326 Phone: 905-628-3232 Fax: 905-628-2529
The reply:
Dear George:
Rick Kozuch
   / Tire Ballast--again. Sorry. #19
Just out of curiosity why don't you just take your tractor to a dealer and have the tires filled with nontoxic RimGuard a product specifically formulated for this purpose?
Andy
   / Tire Ballast--again. Sorry. #20
Andy
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
197359 (A50458)
197359 (A50458)
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
