Tire Clearance on 2520
   / Tire Clearance on 2520 #21
I just had my 2520 at the dealer and again complained about the tires rubbing on the 3 point arms. They turned the tires around and now the valves are on the inside but the tires have gained about 1/5 inches of clearance on each side. I told them it was a bad design and they needed different style arms. They checked with Deere and new arms are coming out this summer so that should fix the problem. I also found that when my tractor came, the lifting mechanisms were in the rear holes on the arms. The arms would not go down far enough to use the I-Match without putting the implement on a pallet for storage. By moving the lifters to the front holes the end of the arms have more up and down range. I am selling my 2520 and attachments to buy a new one this summer. Hopefully the new one will have the new style arms. Good Luck
I ended up going with the 2520 dispite the tire issue. I should have it 2-3 weeks as we are waiting on attchmnt's. The "final straw" in the Kubota v JD arguement was my wife wanting a John Deere. Thanks for all the input and of course I will post some photos. My Kubota is going to a good buddy of mine from work so I will have some visitation rights.
   / Tire Clearance on 2520 #23
I'm new to this site. I just took delivery of a new 2520 last week. Generally I really like the tractor. From the day I looked at it I could see that the rear end of this machine is exactly the same hardware as my older 4100. With the larger and wider rear tires it only figures that the draft arm clearance would be less. First thing I asked the dealer was whether there would be any tire clearance issues with some of the wider cat 1 implements. He said of course not. I have a JD back blade that is 32 inches across the ends of the pins. It rubs the tires on my 4100 unless I turn the tires out to the wide position. Then it has just wide enough to fit chains on the tires. Sure enough, as I expected, as soon as I read all the issues you are all having with tire clearance I went out and tried my back blade on the 2520. I put tires in the wide position, this gave me exactly 2 inches more width. When the 3 point is raised all the way up the draft arms rub on the tires. I need to put chains on this thing too. I have R4 tires. I went to the dealer on Friday and told him I was not happy. He claims that the Cat 1 spec. only allows implements to be 31 inches across the pins. He's never heard about a width problem on the 2520 and claims my back blade is too wide. Anyone know what the spec. says? I tried to google it but can't find the width number. If my implement is not wider then the spec. allows and if there is a JD fix coming I am going to insist they fix this for free. Any odds on that?
Another thing I read on this forum that is very interesting, whether there is a glow plug light on the 2520. Mine has something that sure looks like one. It's on the right side of the dash just below the PTO light. It's yellow and has a symbol that looks like a light bulb on it. It glows yellow for about 10 seconds after you turn the key on. My manual says nothing about this light. The dashboard diagram in the manual shows an outline of the light but assigns no funcion to it and never mentions it. How can some of us have this and some don't? What is it? I asked my dealer and he said just look in the manual. Great! Nice machine but lousy manual and not very knowlegeable dealer.
Also thanks to the guys who mentioned the front wheel spacers that will allow front chains and the lock-up kit that holds the mower lift kit up. Unlike my older 4100 it will be absolutely necessary to hold the lift kit up when not using the mower. The tie rod they have connecting the two sides will get ripped off pretty quick driving around in the woods running a bush hog. These are nice accessories that my dealer had no idea existed until I asked.
Sorry for the long first post.
   / Tire Clearance on 2520 #24
Welcome to TBN BZ:D
As for a CAT 1 3PH spec...well-that is a deep subject! It seems for years there has be no spec other that pin size, and many implement manufacturers just made whatever they wanted. So if you have older stuff than chances are there is no constancy whatsoever!
Now, there is a new push to change this because of all the quick-hitches now available, and JD seemed to lead the charge with the I-Match. There is now a ASAE standard for the dimensions, but still a lot of implement makers do not follow it to the letter. Here are two links with the dimensions:
ASAE
I-Match
And here is another LINK just to muddy the waters a little more..
Now this does not help your situation, but gives you a somewhat vague answer to your question. Getting your dealer to admit to a problem is probably pointless...
Can you modify the blade to be narrower? I have modified several things to fit my I-Match, it is usually not that hard...
   / Tire Clearance on 2520 #25
Thanks for the reply Kennyd, I guess it's not quite so simple. I'm hoping that after seeing all the complaints on this forum that JD has realized it's got some sort of problem and is coming up with a fix. If all else fails I'll probably go with wheel spacers to get the clearance I need. Frustrating! I'll let you all know what my dealer says about this when he checks with JD.
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
1995 Ford Water Truck (NOT RUNNING)(TITLE) (A50774)
1995 Ford Water...
Pro Tech 16' Snowbox (A50774)
Pro Tech 16'...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
