Tire explosion kills farmer.
   / Tire explosion kills farmer. #1
ebme96
Warrensburg, MO
Grasshopper 618, John Deere 60
Recently a guy I knew very well (I hunted his farm for years) decided to air up his tractor tire. This was the front tire on a older John Deere tractor. He is a bachelor and farms by himself for the most part. They found his body two or three days later. Evidently the tire blew up as his one arm, the one holding the tire chuck, was almost severed; and his forehead had an impact. He was only 50 years old, and a very active and likable man. Moral of the story, air pressure has terrible potential.....
   / Tire explosion kills farmer. #2
Keep that in mind next time you pass a big truck and dwaddle along side him. Those tires weigh aqroinf 130 pounds and have 100 + PSI of pressure in them.. If she blows and you are next to it in your car, it's goodbye.,
   / Tire explosion kills farmer. #3
I know, I live near the interstate and hear them blow up once in a while...BOOM!
   / Tire explosion kills farmer. #4
Just this past week , a flatbed was passing me and one of his portable , sliding winches on the rail bounced off . Missed it with my left steer tire but as it slid under truck towards passenger side , I clipped it with the rear , inside drive tire on rear drive axle . Took about 2 miles , if that and brand new tire , maybe 3 months old with 105 psi blew out . I HAD home made lights bars / mud flap hangers on the back . 6" x 2" x 1/8" tubing welded to 1/2" plate , bolted to frame .
That light bar was literally torn off the mounting plate . Welds did not break , it literally ripped the tubing from the plate . The tear was any were from 1/2" from plate on one side , ( the front - closet side to tire ) to maybe 2" on back side of plate . The tubing was also bent backwards in the middle maybe 2" or 3" off center .
Did have 3 led 4" lights in tubing . Center one was gone , outside one was o.k. but inside one , next to frame was o.k. on face but when I took it out of tube , it was Shattered on its backside inside the tube . Now while some damage could be attributed to tire / rubber flinging around , some damage was likely just from the concussion of tire exploding .
That is why most tire places now a days always air tires in cages .
Sorry for the loss of your friend , Neighbor .
Fred H.
   / Tire explosion kills farmer. #5
Our neighbour had a tire on his grain cart blow and it shook the house like an earthquake. I thought my elderly mom had fallen down the stairs.
another story.. we had a drive tire repaired on our 550 and my coworker was lifting it onto the truck when the sidewall blew up in his face. I was certain someone had let a 12 gauge go next to me. He was very lucky, although his ears rang for two days.
   / Tire explosion kills farmer. #6
Recently a guy I knew very well (I hunted his farm for years) decided to air up his tractor tire...
I wonder what air pressure was supposed to be in that tire. Most tractor tire pressures are pretty low...maybe 35 PSI in the fronts. That seems kind of low to cause a catastrophic failure.
   / Tire explosion kills farmer. #7
You said it was "a older John Deere", it may be that the rim had rusted or deteriorated, and that was what failed. When that happens, the flying debris is much worse than when a tire fails.
   / Tire explosion kills farmer. #8
35psi in a large tire is an unbelievable amount of force.
   / Tire explosion kills farmer. #9
Very true...
   / Tire explosion kills farmer. #10
Craftsman ZTL 7000 Mower 42in mowing deck Parts/Project (A55302)
Craftsman ZTL 7000...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55302)
2012 KINZE FLAT...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A56129)
2020 VANGUARD CIMC...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
