tire keeps going flat
   / tire keeps going flat #51
Yeah, something like that. More a bead roll over stress kinda thing. We see this on other equipment. Remember, just a working theory, but if it is happening on machines with no FEL, than .... aw, heck.
Yeah, we had problems like that on our Case.
I used my BX2200 for six years with a FEL and had no problems and the wheels on it are smaller than the BX2660 allowing much more sidewall flex.
Mine leaks down no matter what I have on or what I do. I haven't put my new one on yet; maybe it won't leak too.
   / tire keeps going flat #52
Trying to wrap my head around this. Question.
In all or most of your cases, was FEL work involved? Anyone experiencing low air in front tires, but no FEL attached?
Just a working theory inside my own head right now.
Mine actually did involve alot of FEL work. Now that I have it off, I will monitor the pressures...
   / tire keeps going flat #53
Add me to the list of leaking front tires on a 2660. Gonna slime them. Just crappy tires as far as I'm concerned. I have a 25 year old Cub with the original Goodyears on it that I only air up once a year.
   / tire keeps going flat #54
Could be crappy rims. Maybe they have the crappy rims in a single stack and put only one on each BX.:)
   / tire keeps going flat #55
I have a BX 25 with the smae problem. Right front, to be exact. I have tried slime but it just slows down the leaking process. I just pump it up everytime I go to use it. PITA.
As far as I am concerned the "OTR Traction Master" tires are junk.
Cheers,
   / tire keeps going flat #56
hmm that is strange. I am having a problem wit my fronts too on the BX24. Thought I ruined it or have hole. right front as well. left side needs air every now and then just to maintain pressure. The rears never seems to need air, except when I had bad tire stems. I haven't replaced the stems on front yet and its on my to do list. they are turf tires as well.
   / tire keeps going flat #57
Is this going flat situation specific to a tire type?
R1s going flat?
R3s going flat?
R4s going flat?
If it can narrowed down to tire, we might have a culprit, but if this condition is wide spread over all tire types, then don't we have rim issue? Still just pondering.
   / tire keeps going flat #58
R1s going flat?
R3s going flat?
R4s going flat?
Mine are R4 Traction Masters and am on my third tire and wheel combo.
   / tire keeps going flat #59
BX2660
Front left.
Now has tube.
OTR TractionMaster 18x8.5
Purchased Sep 2008
   / tire keeps going flat #60
BX24
R4 Traction Masters
Front left
No leak after adding slime
Purchased June 08
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
