Tire Sealer ZTR
   / Tire Sealer ZTR #11
Thanks, my local dealer sells something called Multiseal. Any of you guys heard of it? Just noticed that multiseal is the maker of flat out. Wondering why they don't carry the flat out.
Multi Seal is the company and name used on the commercial side. FlatOut is more for the consumer and sells in small bottles. Its the same stuff and company though.
In fact, I have a bottle of the Flatout in each front tire of the tractor, and used the HydroSeal in the filled rears. Don't need the hand pump if you add it to your fill in smaller batches.
   / Tire Sealer ZTR #12
The green stuff from Tractor Supply has worked well for both my ZTR and RTV tires. Slime?
It seems Project Farm did a video on tire sealers a couple years ago, I recall Slime being called the best.
However, after the lithium jump starter fiasco, I don't know how much I would trust PF anymore.
   / Tire Sealer ZTR #13
I have always had great results with what I call John Deere Goop. They just call it Tire Sealer. That stuff works great.
   / Tire Sealer ZTR #14
I live in the land of mesquite thorns and use Slime. 500 hours later and not even a small leak. I don't even bother checking tire pressure any more because it never changes.
   / Tire Sealer ZTR #15
I have used a few different brands over the years the last being Slime, I will NEVER have any of that in any machine I intend to keep. The last time I used it to make it through the last of the mowing season with plans to replace the tires over the winter. Well things did not go as planned and the tires stayed on for another year before I replaced them. What I found was my rims were a horrible mass of rust from the sealant and I know for a fact the inside of the rims were not rusty before the sealant was added. The ONLY way I would use sealant is in a tube so it would never come in contact with the rim.
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
Year: 2004 Make: Sterling Model: Acterra Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2004 Make...
2023 John Deere FC 15R (A50120)
2023 John Deere FC...
Agco 4227 4 Star Tedder (A50774)
Agco 4227 4 Star...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
