TL80a Engine popping - help!!!!
   / TL80a Engine popping - help!!!!
I was wondering the other day if you had this issue resolved. Maybe you list off what exactly you / your mechanic did so far. Do you know on which cylinder she is missing on?
That has been asked before and I assume they are now putting it on the Dyno to get it to act up so they should be able to figure out if is one or all. A little hard when bouncing across a field. Interesting - I wiil call in the morning. Thanks.
Bob
   / TL80a Engine popping - help!!!! #52
It's been awhile and I know we all like conclusions to problems. I just visited the patient at the tractor hospital so - they checked the temp. sensor (adjusts timing on the injection pump) - it was out of spec. helped but still popping. Retimed the pump, off 2 degrees - helped but still popping - sent the injection pump out - nothing wrong - isn't completely back on yet but they are not optimistic. Mechanic was on phone with CNH while I was there asking for their advice. They have worked through the whole report from CNH including valves and everything we already talked about and tested. Sorry no conclusion:( ! There must be a lesson or 6 or 7 here someplace. Very discourageing.
Bob
Please keep us posted on this problem.. I'd like to know what the final outcome is. Has the dealer been able to duplicate in on a dyno?
Yes though the "popping" load range is pretty narrow unfortuneatly it's at pto rpms - if you were using it as a loader tractor you might not ever notice.
Drove the tractor today and it appears to be fixed. Mechanic at the dealership said it was a timing issue and adjustments in the injection pump. I'm not sure what can be adjusted besides timing. Should be home tomorrow or friday - I'll know for sure when I start working it.
Thank you everyone.
Bob
   / TL80a Engine popping - help!!!! #55
What a saga! Glad it's finally fixed but I'll wait for a report from you after you use it for a while. It sounds like RickB was right; some problem in the injection pump.
LOT OF FIRE EXTINGUISHERS (A58374)
LOT OF FIRE...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
