TN65s won,t move forward or reverse
   / TN65s won,t move forward or reverse #51
When you say your tractor no longer shift do you mean that it won't go forward or reverse with the shuttle shift?
This sounds like what happened to my tractor. Its been good ever since I did the repairs in 2012.
Here is a link to the New Holland parts break down of the clutch just check to see that it is the right serial number for you tractor.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
If you have any questions ask away.
Ryan
Yes, tractor will not move forward or reverse with shuttle shift. Almost as if the seat switch isn't working but there is no light indicator that is the issue (it always has shown me a yellow idiot light when I need to sit down).
I'm going to go thru this thread again to do the same troubleshooting steps to see if I can figure it out. I replaced the shuttle shift lever back in December and it worked fine until I was plowing one day. PTO works fine, 3 point goes up and down no issue.
Your problems sound very similar to mine. If you have full hydraulic operation loader, steering & 3 point hitch then it sound like the engine to transmission coupler?? If you do any testing be sure not to run your self over. I would jack the machine off the ground all 4 wheels if it's 4wd. Please keep me updated with your progress as inquiring minds want to know.
Ryan
   / TN65s won,t move forward or reverse #53
Just got the tractor back from dealer yesterday.
Root cause: Main computer
The tractor's computer wouldn't communicate with laptop software. No codes, no response. So they cleaned fuse panel, , replaced all fuses, cleaned wire harness for tach, replaced tractor CPU, reassembled. Works fine now.
Couple of other minor items were fixed such as my loader controls freezing on dump direction in cold weather and then they replaced a few dash panel screws and retainers. Gladly paid the $1950 which included 9 hours shop labor to diagnose and repair.
Could have been much worse. Hope this helps someone else.
That makes sense. Glad you got it fixed.
Thanks for the update.
Ryan
2014 Ford Escape (A50324)
2014 Ford Escape...
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
UNUSED FUTURE SF60 HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
Eagle Weathervane (A55853)
Eagle Weathervane...
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
