TO 20 sticking clutch soln
   / TO 20 sticking clutch soln
SoundGuy,
First, The hydro problem appears to be fixed. Very low on fluid. I know, knuckle head move not to check first.
With regards to the the control linkage. As you are looking in the round viewing cover from the control lever side, there is a pin where the control lever meets the lower section. As noted, in the lift swinging of the control lever, it moves the pin about a .25" in the first half of the control travel. As you continue to move the lever to lift the pin stops moving but the control lever continues to swing up!. The oposite is trure for the lowering fuction. Pin moves very far and moves the entire time the control lever is in motion.
I have not tried to lift anything to heavy, just the grader blade
   / TO 20 sticking clutch soln #12
Are you talking about the lower t-valve on the pump side, or the draft linkage up under the lift cover?
Soundguy
It's the bottom end of the contol lever that is in the casting. It's centered in the access window.
I've started preping for the repaint. I borrowed a sand blaster. I degeased first and will start blasting tomorow.
   / TO 20 sticking clutch soln #14
I'd have to guess that the lift quadrant is a tad out of alignment.
When it was working, were you getting full height out of the lift? Also, keep in mind that there are a few extra linkages under the lift cover that also actuate the fork to the control valve, automatically, depending on draft loads.... still though.. I think your lift is out of adjustment.
I'm not sure if your quadrant adjusts like a 9n/2n or not. Most of the pumping and valving are the same.. but there are subtle differences in the lift cover and pto shaft and coupler.
Soundguy
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
2021 Versatile 405 Tractor (A53485)
2021 Versatile 405...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A55745)
2005 PETERBILT 379...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
