To 240D or Not To 240D
   / To 240D or Not To 240D #1
veedub
Moretown, VT
None yet.
I am looking at a pasquali italian articulating tractor that I think might be just the ticket for my land which is both steep, soft, and generally wet. But I also found a nice 240D that is cheaper and much closer and should be easier to find parts and information for. Currently I run a 1955 Ferguson to-35 which I cant get to 80% of my property with due to traction issues.
I think I have confirmed through research the 240s had a rear locker, do they have front locking axles as well? Is it full time 4wd. I want the tractor for scraping the driveway, some bush hog work, and light logging for personal use. Will the 240 be up to my difficult terrain or should I fork out the extra $1000 and 5 hour drive for the Pasquali?
   / To 240D or Not To 240D #3
No locking FWD, so you basically have 1, 2 or 3wd. U must use locking rear sparingly, if try to turn with it engaged you will break something.
   / To 240D or Not To 240D #4
YM240 is too narrow and tall for what you describe. Sideways on slippery and steep is a recipe for rollover. I never thought about this before someone posted here long ago that he saw their YM240 laying on its side occasionally at a flat warehouse site, probably from a fast turn with raised loader bucket. These aren't heavy and wide like your Ferguson TO-35.
4wd will help go straight up a slope but it won't help much when the tractor wants to slide sideways.
The Italian/Swiss articulated 4wd tractors are made for the steep terrain you describe.
Added: some even have a pto shaft geared for powering a drive axle on the matching trailer. 6 wheel drive, all articulated!
Don't try this with Yanmar!
   / To 240D or Not To 240D #5
Hoye now sells a spacer kit for the rears that I think make the wheel stance 6 to 8 inches wider, without looking again I just don't remember exactly. I want it, but I don't have too many spots where I am on a slope but when you do get there there is a pucker factor
   / To 240D or Not To 240D #6
I had mine on a small side hill cutting grass and hit rut and up off the ground came the Drive wheel. Stopped me dead and sideways on top of that!!! I was moving in the seat awful slow to step on the Rear Differential. If it wasn't for the Mower without a doubt I would have been over. Have to through in a major bomb on that pucker factor. Lucky I was able to get the front wheels turned down hill and the Dr. wheel changed. About the first Yr. I owned it so I learned my lesson quick...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
453 Detroit Diesel Engine (A59213)
453 Detroit Diesel...
2015 Ford F-750 Stellar 10628 10,000lb. Mechanics Crane Service Truck (A56858)
2015 Ford F-750...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
