To Idle or not to Idle, that is the ?
   / To Idle or not to Idle, that is the ? #21
Only time I let it idle is if there is ice or snow on the windshield. Sometimes I use the remote start then get dressed and go out and scrape or brush it off then hop in and go. The remote start only lets it run for 10 minutes then shuts off so the that is the most idle time it gets before moving.
   / To Idle or not to Idle, that is the ? #22
Or you lock the doors and keep a separate remote to unlock the doors with that way somebody can't just open the door and walk off with it.
Aaron Z
Or, you get one of these and put your ignition key on one end and your other keys on the other (that show's how old my truck is; two different keys), or if its single key, just a duplicate for the door lock, and you're good to go. I have this for my 93 Suburban. Our 2013 Impala has remote start, so no key needed.
   / To Idle or not to Idle, that is the ? #23
So if idling your car at startup is so bad for it, why did GM include a remote starter on my car? I use it almost every day. I have a detached garage, so when I walk out the front door, I hit the remote starter. This lets the car run for 30 seconds before I put it in gear and go. If it is bad for the engine, I would think GM would shorten the warranty on cars with a remote starter. Same 6 year / 100,000 mile powertrain warranty as those without the remote starter. Yes, I realize I don't get any MPG for those 30 seconds, but my car makes up for it by shutting off the engine at stop lights and such. Start Stop technology works really well.
   / To Idle or not to Idle, that is the ? #24
Geezers.... in winter, we started our 2000 Impala with one key, locked the doors and let it idle for as long as it took to clear the windows, then went out and drove away. We got rid of it at 186,000 miles two years ago and its still running fine for the lady that bought it. Now I realize that car did not have direct injection, it was throttle body.
'93 Suburban gets the same treatment when its cold and icy.
Our 2013 Impala is GDI. It has remote start. If we have to leave it outside and it gets frost or ice or snow, we start it and let it run, sometimes until it shuts itself off after 10 minutes. Now I realize that someone's going to bring up the valve coking issue because the fuel doesn't hit the back of the valves to clear off any oil that gets past the PCV system, etc........... I'll let you know when it becomes a problem.... 80K miles on it so far.
Its nice to run from a warm house out into the cold and jump into a warm car.
   / To Idle or not to Idle, that is the ? #25
Doesn't get very cold very often around here. I start the car, grab the ice scraper and clean all the windows, then get in and drive. Sometimes my breath freeze on the inside of the window, and needs to be scraped off. Love the heated seats.
   / To Idle or not to Idle, that is the ? #26
Must be nice to have heated seats. My truck idles a bit longer since I have to scrape my butt too.:D
   / To Idle or not to Idle, that is the ? #27
Do not idle a direct injected motor with a high pressure fuel system. It will do just like your friend said. If it's port, heui, common rail, etc..Idle away.
Uh...common rail is a form of high pressure direct injection...is it not? So what causes the fuel to get past the rings and what's different about idling vs running that would change that?
   / To Idle or not to Idle, that is the ? #28
Only reasons I saw on the news story was theft or pollution related. Nothing about the engine itself. Sheep everywhere man....every freaking where that take this garbage hook, line, and sinker...
   / To Idle or not to Idle, that is the ? #29
You're absolutely right, I should have clarified. Do not idle a direct injected NON mechanical motor with a high pressure fuel system.
Furthermore, it should be understood, idling is impossible to avoid. I'm talking excessive idling where the engine has no load and therefore "cool" for and an abnormally long time. A diesel needs heat to expand those rings and prevent washout.
Then there are the emissions systems, but we'll save that for later.
   / To Idle or not to Idle, that is the ? #30
And I think that boils it down... the greenie crowd doesn't like idling vehicles and thieves like to run off with idling vehicles. I just don't see any appreciable benefit, for my situation, to do it but only in very rare circumstances. Winter or summer, vehicle gets started and backed out of garage. About 30 seconds of running to make sure oil has gotten into every little gallery and bearing. Then head down the road. I might use the Onstar app remote start about 2-3 times a year at most. Haven't used it at all this winter.
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58216)
SALTYS...
UNUSED Wheeled Dump Hopper (A55272)
UNUSED Wheeled...
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
Towable Sprayer (A59228)
Towable Sprayer...
2020 DRAGON ESP...
