To paint or not to paint garage/workshop walls
   / To paint or not to paint garage/workshop walls #11
I have built a few shops in my day, my new one is 50x30 with a 20 ft roof, steel building, I am planing on painting the walls it gives you the ability to wash the walls if ever needed. You use a lot less light, to see what you are doing without extra expense. I even painted my benches white.
   / To paint or not to paint garage/workshop walls #12
when I bought my place back in 1981, the garage walls were just unpainted drywall and the roof was unpainted plywood. Very drab and dingy looking. I painted it all an oil based gloss white before I started to put up any shelves, etc and it improved the looks of it 200%! I would definitely advise you to paint it. Worst thing you can do inside a garage is weld! The fumes collect on everything and give it a rust brown look and seem to just soak up the light.
   / To paint or not to paint garage/workshop walls #13
I'd paint it for the light effects, but OSB is a paint sponge. You'll probably need to a good primer and a finish coat to get it to look decent. I'm in the process of redoing a pole barn and I've decided to use interior metal panels. I looked at the cost of OSB and the hassle of painting it and decided the metal wasn't much more expensive.
   / To paint or not to paint garage/workshop walls #14
You are right about OSB being a sponge. The last project I did with OSB I used all the left over paint around the house then top coated with the chosen paint. Gave me a chance to get rid of several partial cans of old paint.
   / To paint or not to paint garage/workshop walls #15
You might also consider finding left over paints (maybe a painter)(or dump) I take a 5 gallon and mix all the latex together,and oil in another and hope for a good color.
but its sure cheap and seals it fine.Makes a good primer coat ..
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
UNUSED AGT SKID STEER QUICK ATTACH SEEDERDRILL (A51244)
UNUSED AGT SKID...
PALLET OF MISC RYOBI ITEMS (A51244)
PALLET OF MISC...
SET OF (2) UTV TIRES, 215/65-14 (A51244)
SET OF (2) UTV...
