Joel/ak
Platinum Member
- Joined
- Mar 22, 2022
- Messages
- 807
- Tractor
- Bobcat 324
Yes, the wilson was made to add weights
My Daystate Huntsman is the Regal and does not have the regulator like the Revere. There is no "pump model"???^^^ Would you recommend the Revere pump model?
Am I confusing side lever cocking for the Revere to be pump operated?My Daystate Huntsman is the Regal and does not have the regulator like the Revere. There is no "pump model"???
If I was buying again, I would spend the extra to get the Revere to see if I could get down to 1/2" at 50 yards. But frankly, I am not sure I can shoot well enough to tell if it would make a difference in accuracy. The issue is being able to read the wind. I am very happy with the Regal.
Here is an article you may find interesting:
Daystate Huntsman Revere Air Rifle .22 Caliber Test Review
The Daystate Huntsman Revere tested by HAM generated Muzzle Energies of between 23.50 and 28.61 Ft/Lbs, depending on the pellet used.hardairmagazine.com
The side lever indexes the magazine and/or opens the action for single feeding. The Daystate is a PCP (Pre-Charged Pnuematic) gun. The thing that looks like another barrel under the barrel is an air reservoir and is filled with air. Air is supplied by a manual pump, electric pump, or a large high pressure air tank.Am I confusing side lever cocking for the Revere to be pump operated?
