paulsharvey
Elite Member
Ballistic Coefficient and Muzzle Velocity. What you say about making an existing bullet longer and heavier, that does work But, most "old cartridges" have too slow of a twist to stabalize long, heavy for caliber projectiles. For example, .270 Win traditionally uses a 1:10, and that will work great for 110gr upto 150gr (some people report working with 160gr RN shorter bullets); but to stabalize some of the slick new "boutique" bullets needs a faster twist. In 277 diameter, thats a special order thing, noone that I know of sells ready to buy 270Win in a 1:8 twist. Creedmore, for instance 1:8 is standard.Qstott,
You sound like you have a lot of long range experience. Can you explain to me in layman's terms why rounds like the .260 and 6.5 are considered superior for long range shooting? Is it a diameter vs length vs weight ratio thing? If that's the case, then why can't those same advantages be made by modifying the bullet length/weight with many other rounds?
I've always liked "fast for caliber" bullets and therefore usually go with a lighter weight bullet in any given chambering. With the .25-06 I always hand loaded 100gr bullets; With the .300 WM, 168gr; .260 Rem 120gr etc. I also usually only hunt with mono-metal bullets such as Barnes TTSX or Hornady GMX, just because I've liked their wound channel performance with less blood shot meat. Plus the mono-metal makers usually suggest lighter bullet weights for better performance.
I'm interested in what makes certain loads better ballistically.
It's more then twist rate as well, and include velocity and barrel length as well, into stability. The fad or trend of 18" .308 barrels, even at the same twisy as a 24"; in theory won't stabalize something on the ragged edge as well, say 220gr pills.
No expert, just a determined idiot here, so if I misspoke, or am flat out wrong, feel free to set me right.
