sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 5,835
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
I traded for my 500 S$W which I had problems with, ended up sending it in to S$W who fixed it free of charge.. needed firing pin work and timing adjustment if I remember correctly. The only gun I have ever sent in!Anyone else buy a used gun that took a while to get back to sending bullets downrange?
David from jax
AHH GOOD, the mandate is pure BS!! The more places that shut down the better.. maybe they will begin to see the error of their ways!Anyone else hearing Hornady shut down due to a walk out over the covid mandate? Trying to confirm.
The problem with that, is our Guberment already has plenty of ammo stashed away, and doesn't care if we run out. Plus they get priority with them when they start back up! Until the walkouts start affecting people who make the laws, or enough people that vote, they don't care about us! I am wondering when they will start mandating trucking company's employees get poked.AHH GOOD, the mandate is pure BS!! The more places that shut down the better.. maybe they will begin to see the error of their ways!
I bought a S&W 64-5 about eight years ago from a guy I met on a shooting forum. It was a security trade in. When I shot it for the first time, everything seemed OK until about the third cylinder full of moderate .38 Special handloads, when the cylinder was starting to bind up, and eventually stopped turning. I took it to a local gunsmith, which I had planned to do anyway to replace the bobbed hammer and sear to change it from double-action-only to regular single/double action. They did the hammer/sear work, but found that the cylinder pin was bent, causing it to bind once it got slightly dirty. So, they sent it to Smith & Wesson for the pin replacement and to check the timing. S&W did that for free, and also paid the return shipping, so I only paid for the hammer and sear replacement, and shipping to S&W. I was without it for about two months. It's been one of my favorite range toys ever since. Just a great-shooting gun.Anyone else buy a used gun that took a while to get back to sending bullets downrange?
6 shots with a 17lb hammer spring.
I am taking a look at how much of the four hundred rounds of ammo that I have, that are loaded from the only brass I purchased used. Can't be over 160 of them, and after that, I will stick with new brass until I run out. I do have the once fired brass sent by "this old grind" and will probably give that a try to see how it works, or I could just use it for reloading 44 magnum and not try to neck it down. I don't have annealing capabilities nor know of anyone that does, so going that route would be another experiment. I have enough new brass to load to last me for a while, and will probably keep my eye out for more as things progress. When I was just shooting the Contender, a box of ammo lasted a lot longer!!With the consistency of neck splits we're seeing from that batch of brass I'd pull some down, get 'em annealed, and reload a few. It's easy for a PO to have overworked belted or rimmed brass by pushing shoulders back too far when sizing. Do we know how many times o'all they've been loaded?
btw, when pulling down ammo the powder is fine for indoor or outdoor plants and at pretty much any time of year. Spread evenly on top or under mulch.
Ruger offered to send me a replacement spring, but "the old grind" had already beat them to it with a selection of springs. From my experience, Ruger would take the gun without question and return it to factory settings, which would undo all the reasons I purchased it for. The gun was manufactured as a 357 magnum with a 6.5" barrel and is now a 357-44 Bain and Davis with a 4.5" barrel and a trigger pull of 2.25. The caliber along with the smooth trigger won't make it past a trip to Ruger!I traded for my 500 S$W which I had problems with, ended up sending it in to S$W who fixed it free of charge.. needed firing pin work and timing adjustment if I remember correctly. The only gun I have ever sent in!
