Verticaltrx
Veteran Member
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I have three trucks with carb's (two of which also have points) and honestly they aren't that bad to drive in the winter. Pull the choke, pump the pedal, and they fire right up. Set the choke about halfway in and drive a few miles, then push it all the way in. Granted, these are old work trucks and not my daily driver, but I think if a vehicle is well maintained and kept in good tune they should start and run fine regardless of the weather.
The exception is my '79 F-150, which is built for 'wheeling and rock crawling. It has a fairly built 351w, Quadra-jet carb and HEI distributor. As with everything else the carb has built built and tweeked to provide max power and run at crazy angles, and one of the mods was removing the choke assy and pinning the choke plate open. The motor is also tuned pretty lean for max power. It can be a bear to start when it is cold out. Pump the pedal dozens and dozens of times, crank, pump some more, crank, crank, crank, etc. Good thing it has an Optima red top battery, sometimes it takes what seems like close to a minute of cranking to get it started. Takes forever to warm up and idle as well. However, once it has been started and is warm, you hit the key and the motor doesn't even make a full revolution before it starts. That always impressed me as fuel injected motors have to crank a few times before they start even when warm.
On a side note, one nice thing about having a couple vehicles with points is I'll still have something to drive if we ever have one of these 'electromagnetic events' they talk about. :confused2:
