Tomato cages--what do you use?
   / Tomato cages--what do you use? #31
As others have said, I made my tomato cages of concrete reinforcing wire about 2' diameter. I cut them so the bottom wires stuck into the ground, but I also used two 1" x 2" wooden stakes for each cage because I had more 1" x 2" lumber than I knew what to do with.:laughing: I was planting a dozen each of 4 varieties of tomato. At the end of the season, I used a machete to chop off most of what had grown out through the cages, which made them easy to pull up and store in the barn for the Winter.
I use the same machete to chop up the dead vines before they go into the compost.
   / Tomato cages--what do you use? #32
Do you not worry about bringing bugs/disease from the old tomato plants into your compost to use on new tomato plants?
   / Tomato cages--what do you use? #33
Hasn't been a problem; particularly if the compost generates sufficient heat. But you are of course correct; I shouldn't be composting diseased plants. I haven't had any disease problems for quite a few years; had Red Spider a few years back, but haven't had anything worse than a few yellowed leaves in recent years, not even aphids.
   / Tomato cages--what do you use? #34
I like this set up. A nearby OG farm grows their tomatoes this way.
I only grow six plants at home. I take old cattle panels and have lots of scrap sizes. I just ziptie them together to make a square or triangle and the tomatoes way outgrow the set up but they are pretty easy to pick and access. "keep on compostin'"
FAKE (A52472)
FAKE (A52472)
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
197711 (A51244)
197711 (A51244)
Adams Tender / Magnolia Trailer (A55301)
Adams Tender /...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
