Took me less than two hours to
   / Took me less than two hours to #11
I bent my tierod last year. I heated it up in and straightened it in a vise. This did weaken the tierod and it bent again even worse about a month ago. I knew the day would come, so I had bought a new one from the dealer.
For me.. straighten it out to get yourself back up and running.. then buy a new one for a backup.
Anyone have a skid plate attachement idea for the CK25??
   / Took me less than two hours to #12
you can heat it but it will be weaker after that. I used a press to straighten mine................three times. The boots on the ball joints will tear with a ball joint fork. At you local auto parts store go to the "Help me" section. They have boots that will work fine for a couple of bucks each
   / Took me less than two hours to #13
Yep, a must at my place.
   / Took me less than two hours to #14
Nice work RedRocker. Too bad there isn't a big market for it - would make a nice niche business and maybe some good $$ for you. I'm surprized you didn't paint it orange ;).
   / Took me less than two hours to #15
Very nice work Redrocker! An underside view would be nice too ;) !
   / Took me less than two hours to #16
An old Jeepers trick... Straighten the tie rod best you can. Then, set your toe-in. Now, weld a pies of 1"-1.5" angle iron on there. It will strengthen it, and if placed correctly, act as a skid too.
Common issue with hard rock 4x4's...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2008 Featherlite Portable Office Command Center Trailer with Wacker Neuson MGT2E Towable Generator (A55788)
2008 Featherlite...
2012 LAMAR TRAILER 20 T/A UTILITY TRAILER (A55745)
2012 LAMAR TRAILER...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
