tool box ideas for 3x20 tractors
   / tool box ideas for 3x20 tractors #11
I mounted 2 small ammo cans through the existing holes in the rops, on the outside, directly below the flashers. I drilled through the cans and put a long bolt through them. I use them for carrying chains so I took the lids off and drilled holes in the bottom for drainage. Larger ammo cans with lids could have been used for toolboxes.
   / tool box ideas for 3x20 tractors #12
   / tool box ideas for 3x20 tractors #13
hi. could you tell me what those brackets are that are holding the box against the Imatch? am trying to figure out how to mount my tool box and can't see what they are from the photo. thanks
   / tool box ideas for 3x20 tractors #14
   / tool box ideas for 3x20 tractors #15
Quick hitch---see pic. Chains easily at hand & saves the tractor fenders from abuse.
   / tool box ideas for 3x20 tractors #16
   / tool box ideas for 3x20 tractors #17
The brackets are just square c-clamp type bolts I bought at Ace Hardware; a local hardware store. about $3-4 each I believe. I drilled four holes in the box. Careful to place a flat piece of metal on the inside of the box to avoid warping it. I really like al3's heavier duty boxes.
   / tool box ideas for 3x20 tractors #18
jd3520-
how do you like your bb2060 boxblade? i just traded up to one and got an iMatch.
jd3520-
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
SCAN TO RECEIVE TEXT UPDATES (A54756)
SCAN TO RECEIVE...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
