tool box ideas for 3x20 tractors
   / tool box ideas for 3x20 tractors #11
I mounted 2 small ammo cans through the existing holes in the rops, on the outside, directly below the flashers. I drilled through the cans and put a long bolt through them. I use them for carrying chains so I took the lids off and drilled holes in the bottom for drainage. Larger ammo cans with lids could have been used for toolboxes.
   / tool box ideas for 3x20 tractors #12
   / tool box ideas for 3x20 tractors #13
hi. could you tell me what those brackets are that are holding the box against the Imatch? am trying to figure out how to mount my tool box and can't see what they are from the photo. thanks
   / tool box ideas for 3x20 tractors #14
   / tool box ideas for 3x20 tractors #15
Quick hitch---see pic. Chains easily at hand & saves the tractor fenders from abuse.
   / tool box ideas for 3x20 tractors #16
   / tool box ideas for 3x20 tractors #17
The brackets are just square c-clamp type bolts I bought at Ace Hardware; a local hardware store. about $3-4 each I believe. I drilled four holes in the box. Careful to place a flat piece of metal on the inside of the box to avoid warping it. I really like al3's heavier duty boxes.
   / tool box ideas for 3x20 tractors #18
jd3520-
how do you like your bb2060 boxblade? i just traded up to one and got an iMatch.
jd3520-
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
