mmancuso13
- Joined
- Jan 8, 2017
- Messages
- 212
- Location
- Sykesville, MD
- Tractor
- Bobcat Toolcat 5600, Kubota RTV-X1100C
Hey all, my TC is dead once again with the 50-56 code as before.
Unfortunately it is deep in my barn and will be a bear to drag out. I ordered a set of hydraulic wheel dollies from eBay in the hopes it will help me get the machine out of its storage location in case this becomes a "dealer" issue.
I am going to go through the 50-56 code electrical tests but can anyone out here tell me how likely it is that they will discover a problem?
It seems to me that everything on the procedure leads to a replace of the display or drive controller but most test focus on trying g to find a bad wire harness.
Because my problems are intermittent I cannot believe it is a failure of either module. More likely it is a bad connection or corroded connector (my machine was used as snow / salt machine for a University before I bought it).
Should I just pull and check all connectors first - the wiggle test, as recommended by many th last time I had this issue?
Thanks in advance,
Matt
Thanks in advance,
Matt
