Tooth Bar or not to tooth bar
   / Tooth Bar or not to tooth bar #1
Timmmmah
Reno,NV
2005 L 3130 FST
I am taking delivery of my L 3130 with 723 FEL on the 20th, I am wondering if a tooth bar is a worthy attachment.. I have pretty rocky soil... any feedback appreciated
   / Tooth Bar or not to tooth bar #2
worthy?
Oh yes! In terms of breaking material up, very useful. Not only piles, but ground material too. Backdragging, one could find it used as a quick rake.
Mine is on the FEL full-time.
-Mike Z. /forums/images/graemlins/grin.gif
Plenty of other comments in the attachments forum.
   / Tooth Bar or not to tooth bar #3
If you do a search on toothbars on TBN you will find: 1) lots of posts, 2) almost all very enthusiastic about adding a toothbar if you are digging or brush clearing. Only real negative would be if you are primarily moving piles of dirt, gravel etc as it would not add anything but extra weight (about 70-100 lbs) to the bucket.
   / Tooth Bar or not to tooth bar #4
I bought one for my 2410. It's not attached alot but when a project calls for it, the difference is tremendous.
It's on and off with 4 bolts, so if you aren't moving soil or the like that calls for that attachment, just leave it off!!
   / Tooth Bar or not to tooth bar #5
[I am wondering if a tooth bar is a worthy attachment]
I had a toothbar on the FEL bucket on my previous tractor (BX-23). The toothbar made a world of difference for digging, removing ground vines/brush/rocks, and gave the bucket some degree of protection when digging. My current tractor is an L3430 and I just purchased a new Woods toothbar for the bucket. I expect the toothbar will be more effective on the larger bucket when I continue my brush clearing efforts in the spring.
Jim
   / Tooth Bar or not to tooth bar #6
<font color="blue"> Only real negative would be if you are primarily moving piles of dirt, gravel etc as it would not add anything but extra weight (about 70-100 lbs) to the bucket.
</font>
This may or may not be true depending on the loader.
I have noticed that my toothbar, due to its design, actually increases the length of the bottom of the bucket. The net affect is that the bucket will hold more than it does without the toothbar installed. (mine comes off/on in a couple minutes)
A weak loader would not benefit from added bucket capacity though...with mine I do notice the difference and like having the toothbar on most of the time.
H & H made mine, which is a little more expensive than some of the others out there, but very durable due to its design, and makes the lower lip indestructable on my little tractor (B2910 kubota).
   / Tooth Bar or not to tooth bar #7
most certainly get one, i use mine all the time, on and off in 2min. great help for certain tasks
   / Tooth Bar or not to tooth bar #8
I can tell you, by far the most cost effective investment I have ever made in any attachment has been my tooth bar…..
Attached is one of many “rocks” I have dug out using nothing more than my FEL with the tooth bar.
Gary
   / Tooth Bar or not to tooth bar #9
</font><font color="blue" class="small">( “rocks” )</font>
Right. What do you classify as a boulder? /forums/images/graemlins/grin.gif
And the question of the toothbar, it saves your bucket edge too!
   / Tooth Bar or not to tooth bar #10
A toothbar is great for digging into compacted earth. I'm using mine to excavate for a paver block walkway.
I have a big pile of fill dirt left over from the excavation work last summer on my new house. I find that I get better results without the toothbar when digging into this pile, moving the dirt around, and touching up the grading around my foundation and elsewhere on the property. Fortunately it's a Markham toothbar held on with two 1/2" bolts so it's a snap to get it on and off the bucket.
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2013 TIGER CAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGER CAT...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
