Grading Tooth Blade for FEL on BX22?
   / Tooth Blade for FEL on BX22? #1
Anonymous Poster
Epic Contributor
Well, I did it. Spent the last few weeks lurking on this forum and decided to get a BX22. It's getting delivered Friday. My question for you folks is wether or not I should have the dealer install a tooth blade on the FEL. Initial profects will include spreading a lot of dirt from a large mound. Will the tooth blade help that much? He wants $275 for it. Thanks.
   / Tooth Blade for FEL on BX22? #2
Welcome! Always nice to have some new blood to add to the mix!
I can't speak from experience since I don't have a tractor yet. But from everything I've read, and I would strongly urge you to do a search for "toothbars" (I think you'll find a wealth of information! /w3tcompact/icons/wink.gif), I would think it would be an advantage to have one. If your large mound of dirt is at all compacted, the toothbar will make filling your bucket a whole lot easier. As for spreading the dirt, you can use your bucket in the float position and backdrag it to smooth things out. You would need to to tip the front of the bucket up just a little so that the back side of the bucket is doing the smoothing.
Again, do a search. You'll find that your questions have been asked and answered many times in the past! /w3tcompact/icons/smile.gif
Thanks. Silly me was searching under "tooth blade"
   / Tooth Blade for FEL on BX22? #4
I don't think a tooth bar will be any help in spreading and smoothing dirt, but it's really a BIG help in digging, whether digging a hole or digging into piles of dirt (unless it's very loose, fluffy dirt).
   / Tooth Blade for FEL on BX22? #5
Bird -"Fluffy dirt"? Ok, I have see rocky, wet, mucky, clean, dry, hardpan, sandy, and others to name a few. But you got me on "Fluffy" /w3tcompact/icons/smile.gif
   / Tooth Blade for FEL on BX22? #6
/w3tcompact/icons/laugh.gifMaybe not a good description for dirt, huh?/w3tcompact/icons/laugh.gif However, my old dictionary includes, as a definition of fluffy, "being light and soft or airy".
   / Tooth Blade for FEL on BX22? #7
"being light and soft or airy". Hmmm! Is that the same as dust? :) That stuff is hard to load in my FEL.
Don
   / Tooth Blade for FEL on BX22? #8
Sounds like dust to me too /w3tcompact/icons/laugh.gif. While I recommend the tooh bar for any FEL, I don't know if you can get it with a broom./w3tcompact/icons/smile.gif
   / Tooth Blade for FEL on BX22? #9
Go for the tooth bar, I used mine last night as I tilled a landscape site. You can actually level high spots with the fel and tooth bar dragging the ground while the tiller is engaged. It also allows for loading of bulky items like rolls of landscape fabric and the fel can carry more in the bucket when moving mulch.
   / Tooth Blade for FEL on BX22? #10
PAJohn - I'm going to go slightly against the grain here. You are talking about a BX22 with a backhoe, right? I chose to pass on the toothbar(for now).
I use the backhoe to dig and break up piles of dirt(some sitting for 3-4 yrs). I'm pretty sure that's what a backhoe is supposed to do......dig. I use my loader....to....er....well....load. One advantage to having the toothbar would be for a little more stability when putting the bucket edge down to create the "tripod" for backhoe work. I haven't found it to be a handicap not having a toothbar...yet.
If you have the money to spend now.......go for it. Otherwise you can use the money toward some other implement you need now. It can always be added later.
If you're talking about a BX2200 without a backhoe.....then....follow the advice of the others. You have no choice than to use your "load"er to dig. C
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
City of Lakeland (A51691)
City of Lakeland...
SCHAFFER 2430SLT LOT NUMBER 150 (A53084)
SCHAFFER 2430SLT...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
