toro mower deck
/ toro mower deck #1
csgrant12
toro wheelhorse
I have a toro wheelhorse riding lawnmower, the engage blade leverstopped working? anyone else had this problem?
/ toro mower deck #2
Just a shot here cause of limited info, no model number hydro or manual tranny, belt or shaft driven===. So electric clutch failure.
DevilDog
/ toro mower deck
it is a hydro , belt drive. There is a cable attached to the lever that seems loose ( a lot of play)
/ toro mower deck #4
I'm only guessing, but when you move that lever doesn't that cable move a pulley against a belt that goes to the pulley on the mower deck spindle? Sounds like a simple adjustment unless the spring is missing from the pulley, or the pulley itself has come off or the belt has come off the pulley. In other words, hard to say without seeing it, but I'd expect it to be a simple fix.
/ toro mower deck
thanks all. The blade control cable snappped.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2004 Sterling Acterra Bucket Truck, VIN # 2FZACGCS04AM54361 (A61165)
2004 Sterling...
2010 New Holland Boomer 3050 Tractor Loader (A63116)
2010 New Holland...
40ft High Cube Shipping Container (A61166)
40ft High Cube...
