Rotary Cutter Toughest rotary cutter brands?
   / Toughest rotary cutter brands? #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
I have an old Bush Hog brand 5 ft rotary cutter that has become too small for my needs. I want to replace it with something as tough as it is. Who makes the toughest rotary cutters out there? I want something to cut mostly hay feild edges and fence rows, but tough enough to cut small saplings. I was thinking about 7ft wide. Heavy Duty. What should I expect to pay? The old one has a rubber clutch type deal. Is that still available? What's best? Shear Bolt type?
   / Toughest rotary cutter brands? #3
Get a Rhino or another Bush Hog mower -- stay away from the Woods brand, they have poor qualilty.
My more detailed reasons from the past.
   / Toughest rotary cutter brands? #4
</font><font color="blue" class="small">( I was thinking about 7ft wide. Heavy Duty. )</font>
You get what you pay for, more or less.
As far as I know, all brands make heavy duty cutters that will outlast you. Most will cut 2" saplings without breaking. Most 6' and larger cutters have a clutch instead of the more problematic shear pins. The true HD cutters will cost a lot more than standard duty cutters, but are worth it depending on your work.
   / Toughest rotary cutter brands? #5
sidewinder makes some tough cutters, they are operated in missouri as gilcrest now.
heehaw
   / Toughest rotary cutter brands? #6
I've had really good work out of a 60" Landpride. I was really amazed at some of the stuff I cut down.
They make larger units as well.
This 60" cutter was just over a grand. Going to 72" or larger will probably take you to the $1500 to $2000 mark pretty quickly.
   / Toughest rotary cutter brands? #7
They use one on the army base to cut roads. Its a Hydro Ax.
   / Toughest rotary cutter brands? #8
Check out a Brown for the "King of Heavy Duty " hope your tractor has the power to work it. /forums/images/graemlins/smile.gif
   / Toughest rotary cutter brands? #9
I purchased a Brown 484 for $2200 - add front chains for $125
Best value I found in a HD rotary cutter. It will easily take care of hardwood saplings up to 4", and then some.
Have about 40 hours on mine reclaiming old pasture land overgrown with multiflora rose, privet, locust, etc.
I like it. I compared the specs and prices on quite a few before deciding on this one.
I called Brown Mfg. to find a local dealer and was put thru to Mr. Brown himself. I like dealing with a company where the owners and mgrs are on the front line.
   / Toughest rotary cutter brands? #10
<font color="blue"> I was thinking about 7ft wide. Heavy Duty. What
should I expect to pay? </font>
The IMC 7 ft with dual tailwheels coming in at around $1750 is a tough machine--I cleared 50 acres on a old farm with saplings up to 4 inchs about 8 years ago with a 3 point version and when finished, I discounted it $100 from regular price and sold it retail, right away (only had a few scratches down the sides)--Ken Sweet
Sweet Farm Equipment Co *Now 2 locations to serve you*
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A52576)
2016 KENWORTH T680...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
ASV Posi Tool Backhoe Quick Attach (A51573)
ASV Posi Tool...
