Tow behind wood chipper
   / Tow behind wood chipper #1
timberwolves
Bronze Member
Delaware County, N.Y. & Seaford, L.I.
Massey Ferguson MF-65
I have a Morbark Eeger Beever model 200 tow behind wood chipper. I need to adjust the knives on this unit. I was told the tolerances were 50 - 100 thousands of an inch from the highest blade. Does anyone know how to make these adjustments ? I have installed new blades already and when I use the chipper the wood chips are big. It is my understanding that adjusting them it will make the wood chips smaller. Thank you John
   / Tow behind wood chipper #2
If I'm correct the Eager Beaver is a flywheel chipper not a drum. Typically this adjustment is made with the "bed blade". It might not look like a blade but a plate that adjusts in and out from the flywheel. A wider gap will result in larger chips and takes more power but chips faster. A closer gap will produce smaller chips and take less power but chips slower. Which engine does yours have? I think they had a 80hp gasoline and a 76hp cummins diesel. The cummins might have a little more torque.
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2021 CATERPILLAR 279D3 SKID STEER (A52705)
2021 CATERPILLAR...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2022 PETERBILT 579 TANDEM AXLE SLEEPER (A54607)
2022 PETERBILT 579...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
