Tow motorcycle with a tractor (adapter for 2" receiver hitch)
   / Tow motorcycle with a tractor (adapter for 2" receiver hitch) #11
Now if it only went all the way to the ground for easy loading...
Some do. Here is one using a small winch. More videos on the right side, too, if you click to view it on Youtube.
Bruce
   / Tow motorcycle with a tractor (adapter for 2" receiver hitch) #12
I pulled my Honda XL 250 behind my Cordoba back in the 70's. I took the front wheel off and clamped the fork to the tow frame. The first time down the road doing about 60 I was really impressed by how well it worked. After about 20 miles it started acting funny, so I stopped to check it. I had just put the cycle in neutral, but turns out a transmission shaft was being turned by the rear wheel without being oiled and had seized up. From then on I took the chain off to tow, and pulled that rig several thousand miles.
(2) 5' TRAILER RAMPS (A57192)
(2) 5' TRAILER...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2014 Ford F-250...
2008 Dodge Ram 1500 (A55973)
2008 Dodge Ram...
1996 International Water Truck with a Caterpillar Engine (A55315)
1996 International...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
