Towing a 12K rated trailer in Pa
   / Towing a 12K rated trailer in Pa #21
So if you are a guy that is in to tractor pulling and have 2 tractors trailer and a F650 and go to tractor pulls and the whole rig weigh's over the magical 26001lbs in PA and that is were the OP resides you can get get a non commercial A class license and save some money any headaches of a CDL.
Is that rig considered an RV? If it is not I don't see how you figure that a non commercial A will do. Even then tractor pulling is generally considered to be in commerce requiring USDOT number and the whole jive.
   / Towing a 12K rated trailer in Pa #23
Just stumbled across this post. I know it is old, but I thought I would share what I know on the subject. As for the requirements for a combo registration. When I purchased my 2018 RAM 3500 SRW, I registered it as a weight class 8. I did this because my max GCVWR for my truck is 22,900 pounds and I knew I would be towing a trailer over 10,000 pounds. A weight class 8 is for a combo weight of 21,001 to 26,000 pounds. Currently, my annual registration cost is $559.00 dollars.(Google PA MV-70s for a complete list of weights and fees) I currently tow a 16 foot 12,000 pound dump trailer (de-rated from 14,000 pounds to stay under my GCVWR of 22,900 pounds). I do not require a Class A drivers license because my GCVW is under 26,001 pounds. I also do not require a USDOT number because I use my trailer for personal use. Also, since my trailer's GVWR is over 10,000 pounds it must be inspected by a "Code 3" qualified heavy truck/heavy trailer (10000#+)/bus mechanic annually.
   / Towing a 12K rated trailer in Pa #24
To reactivate this old thread: I'm from Missouri, how does this apply to a out of state driver?
I have a '94 F-350 diesel with a 9200# GVWR, nothing about a CGVWR although Ford literature says I can tow 14,000#. My plates are for 18,000 non local. Missouri DMV says that I do not need a CDL and that my plates are for actual weight combined weight.
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
