Towing in a somewhat snowy area -- 4x4 vs 4x2
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #1
mundamanu
Schoharie, NY
TC40A, Ford 8600, MF65
My wife and I are looking to get a truck to tow a simple two-horse bumper-pull trailer. We are leaning toward a new or recent model F-150.*
We will be living about 40 miles west of Albany, NY and should average about 50" of snow per winter, which for me, having grown up in Syracuse, NY is not a lot of snow, but I have never towed a loaded horse trailer in the snow. Regardless, we expect to do very little towing in the winter. In fact, we are likely to do no elective towing at all in the winter.
Money is very tight right now and will continue to be so for the next five years, so we need to save money where we can.
So, my question is, can we get away with a two-wheel drive truck, or do we need (must we) to get a 4x4? I would, and I am sure most of you would, prefer a 4x4, but I need to know if we need a 4x4. Three thousand dollars is a lot of money to spend on something that we don't need.
Any advice would be greatly appreciated. Thank you.
*I have plugged all of the numbers, and in the appropriate configuration (Reg. cab, long bed, 5.4L V8, 3.73 limited slip, standard payload pkg) the F-150 is plenty big enough to fit our needs, with at least 10% to spare in payload, GVWR, and GCWR.
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #2
You could get by with the 3.55 rear end and a 4.6 in a new truck and be alright. My new F-150 is rated for a 6200 lb trailer with a 4.6 and a 3.55 rear end. My neighbor pulls her horsers with a comparable truck to mine except hers is a supercab model. As far as 4x2 vs. 4x4 I would go with the 4x4 but the 4x2 would work. Regardless the truck will have weight on the rear tires with a loaded horse trailer which will help in traction a little. The thing is though where are you going to take your horses and where will you be turning around and suchwhenyou get there and at your barn for that. I think that is where you would want the 4x4 instead. If you could find an older F-150 I would get the 351 (5.8L V8) as the 302 (5.0) does not pull very well inmy opinion. If you found an older 3/4 ton then any engine would work fine (pre 98: 5.8-351 V8, 7.5L-460 V8. or a 7.3L V8 diesel-turbo/non turbo maybe a 6.9L V8 diesel in the early 80's models).
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #3
If you do go with 4x2, go with the limited slip rear axle. That will help quite a bit. I had a '97 F150 with it. We don't get much snow here, but I had it in the mud where I hunt numerous times. Had to work with it sometimes, but never got stuck.
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #4
alright here is my opinion. get yourself, or your wife, or kid a job at home depot for 12 hours a week and take advantage of their discount car programs. then you getn get a 3/4 ton chevy with 4wd for less then an f-150. not trying to start a flame war, but in my area chevys are just cheaper. i saved 8k over a camparable f-250 when i bought my 2500hd with the d-max and allison, and i paid under 30K well under.....i knew home depot was worth something! oh then once you sign your contract and all that fun stuff....quit depot.
hope this helps. if you have an specific questions pm me.
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #5
Heck you don't have to go to Home Depot. Anyday of the week my dealer will sell for $500 under invoice. Tough to beat that with any program.
As far as 4wd there's no way in snow I would pull a trailer with horses without 4wd. Yes you can get by with 2wd but the safety factor is a 100 fold in my opinion. It is much easier to jackknife with 2wd and pulling a trailer you really the 4wd for steering in the snow and ice. I've pulled with and without 4wd and the extra $3k wouldn't come close to replacing one of our horses much less one of the family. If you lived in AZ or down south I'd say save the money. Where you are in a definite snow/ice zone get the 4wd. You'll forget about that extra $3k long before you get over the feeling of sliding around in 2wd or worse yet getting in an accident.
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #6
I would go with 4X4 because even though the 4X2 may be fine, there will be one time when you will need it and when its freezing cold outside your wife isn't going to want to hear about the money you saved setting stuck in the snow or mud. It is also a good investment as it is a lot easier to sell a truck with 4X4 than without. I just sold my wife's S-10 and everybody that called about it wanted to know if it had 4 wheel drive and it didn't so I took a loss on it. It isn't always snow that could require 4X4, my dad was backing his car trailer in the yard to unload the tractor and a little hill matched with wet grass kept taking the weight off the rear end and required to put it in 4X4.
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #7
KubotaSteve,
You hit the answer on two counts from my perspective. I get 4x4 because I might not need it often but when I do need it I need it BAD!
Its tick and worse, chigger, season in NC. Last weekend I wanted to look at one part of the property. Even with treated pants I did not want to walk back to what I wanted to check. So I put the truck in 4x4, more to lube the front diff than out of need, and drove off through the woods on a tractor trail.
The truck is a F350 Crew Cab with an 8' bed. It is big. The trail is small. My turnaround faces down hill and I have to back up hill. Never been a problem. But the grass is long and I'm sure the Tiltmeter would say 10+ degrees. /forums/images/graemlins/frown.gif
Well, the wheels started spinning. Could not move back at all. So I had to get out of the truck, lock the hubs, and then I could back up. I THINK if I had driven forward a bit I could have back up. But maybe not. Then it would have been the tractor time...
Took seconds to lock the hubs and drive out. I'm sure it would have taken 20-30 minutes if I could not have found another way to drive out and had to hook up the tractor to the truck.
BTW. Even locking the hubs I managed to stay tick and chigger free! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif That is worth 4x4 dollars!!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Later,
Dan
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #8
I think Dan has a good point. The 4WD will be handy if you get in a tough spot. You don't want to engage the front end for towing on the road, though. From personal experience, I can tell you that unless the truck has a differential in the transfer case, it can get you in trouble.
Cowboydoc,
You make an important point, I think. There will not be hay, or lumber, or some piece of equipment in that trailer, there will be horses. Getting stuck is one thing. Getting into an accident while pulling a trailer loaded with horses is another. I would hate to know that we hurt, or worse, one or more of our horses because my wife and I wanted to keep some money in the bank.
I believe the 4x4s have it. /forums/images/graemlins/wink.gif
Thank you everyone for the help.
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #10
Subaru has a truck type vehicle called the Baja with the towing capacity of GVWR 4555, horses and a trailer would probably weigh a little less than that probably at that. And best of all AWD is standard and its made by Subaru, they make some excellent products.
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
