Towing in a somewhat snowy area -- 4x4 vs 4x2
   / Towing in a somewhat snowy area -- 4x4 vs 4x2
Degree,
Thank you for the heads up on the Subaru Baja, but the Baja has a manufacturer's maximum towing capacity of only 2400 lbs, which means that it is actually less than that.
When I started looking into towing vehicles, it became quickly apparent that properly matching up a vehicle to a proposed towing task is much less straightforward than simply looking at the manufacturers maximum towing capacity, which is different from the GVWR.
When considering towing, all of the following variables need to be considered. The manufacturer sets a limit, or rate (R), for each variable and no single variable can be exceeded.
________________________________________
<font color="blue">GVW (gross vehicle weight) </font> = Vehicle base curb weight* + passengers + cargo + trailer tongue weight (bumper pull) or trailer king pin weight (gooseneck, or fifth-wheel)**
<font color="blue"> GCVW (gross combination vehicle weight)</font> = GVW + Total loaded trailer weight
<font color="blue"> Payload </font> = GVWR minus Base curb weight (when calculating your actual payload, you must include all passengers [-150 already included], any and all cargo, and tongue weight or king pin weight)
You should also keep an eye on axel weight ratings, but I have found that if you don't exceed any of the above, you are unlikely to exceed the axel ratings. However, I have not calculated for a 5th wheel. The rear axel rating may be important when figuring for a 5th wheel.
*Ford's base curb weight includes an empty vehicle with standard options, a full tank of gas, and one 150lb passenger. (I imagine that is a standard calculation, but I do not know)
**For calculation purposes, trailer tongue and king pin weight should be estimated at 10%-15% and 15%-25% of total loaded trailer weight, respectively. Tongue and king pin weight, however, is not important only for towing maximums. The tongue and king pin weights must be within those percentage ranges for safe towing. If your tongue or king pin weight is too heavy or too light, the resulting down or up pressure can cause dangerous lightness in the front end or rear end, respectively.
It is important to note also that when selecting a towing vehicle, the particular configuration (wheel base [on pick-ups this is most affected by cab style and bed length], engine size and type, drive train, and axel gear ratio) makes a significant difference in a vehicle's maximum towing capacity.
Run the numbers before you buy! Overestimate your cargo; stuff is heavy!
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #12
*smacks head* im sorry i didnt know what i was talking about.
Until about a month or two ago, when I started to get serious about buying a truck, I didn't know a GVW or a GAW from a hole in the ground. Tongue weight? I reckoned mine weighs about four ounces, tops, and while I can be a chatty matty if you get me going, I couldn't believe it would be enough to put the trailer load over the top. /forums/images/graemlins/tongue.gif
   / Towing in a somewhat snowy area -- 4x4 vs 4x2 #14
<font color="purple"> If you lived in AZ or down south I'd say save the money </font>
Heh, here in AZ you'll use 4wd year round. Many is the dirt road that crosses a very sandy wash, just like driving on a beach. There are often road signs reminding the driver to switch to 4wd.
And if you want to go off-road, it'll be washes and rock-crawling.
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2018 CASE IH 110N LOT IDENTIFIER 208 (A53084)
2018 CASE IH 110N...
