Towing Three Balers Behind One Tractor
   / Towing Three Balers Behind One Tractor #1
Grrrr
Platinum Member
Devon, UK
John Deere!
Anyone ever seen this before?
More Pictures and M/F site here
Noticed it when I was browsing Google.
Looks like one way to get full use of extra HP :D
   / Towing Three Balers Behind One Tractor #2
Considering each of those balers only needs about a 40 hp tractor in front of it then yes that would be putting additional hp to good use.
I have never seen anything like that before, must be out west somewhere.
I was thinking you were going to need to be pretty accurate with raking to keep the rows all equidistant apart. (Unless each baler can be moved sideways to follow the windrow.
   / Towing Three Balers Behind One Tractor #4
Under one of the pictures on the website it says that it can be adjusted on the fly.
   / Towing Three Balers Behind One Tractor #5
I'd bet the operator could also be a world champion accordian player !! MikeD74T
   / Towing Three Balers Behind One Tractor #6
It'd take 20 acres to turn that rig around :eek:
I'm doing good to keep ONE baler on track and adjusted. Ain't no way......
   / Towing Three Balers Behind One Tractor #7
Looks intriguing. Also looks like it could be a real pain to operate.
If I was making hay there would be one bigger baler back there.:D
   / Towing Three Balers Behind One Tractor #8
I think its pretty darn cool!!!! :D
BTW there are instances when small bales are what the customer wants and this is a very inventive means of covering a large area fast!! Inlines are perfectly suited to this setup.
   / Towing Three Balers Behind One Tractor #9
From the looks of the pics, this set-up is being used in an area where yields are low. Up in this neck of the woods, no way would this set-up work. I've seen 125HP tractors struggling to handle the load when bailing timothy. This was using HD freeman sq bailers. They can eat a lot of hay and you'll see some with a wheel rake at the mouth to help gather up the windrows.
This operator has to be busy trying to keep these 3 bailers lined up.
Interesting pics.
I think I find it bad enough when one baler is playing clown but having three all playing clowns when you want to be baling would be no fun for me ;)
2016 Chevrolet Caprice Sedan (A55758)
2016 Chevrolet...
UNUSED LANDHONOR 11' X 19' ALL-STEEL CARPORT (A54757)
UNUSED LANDHONOR...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
UNUSED FUTURE HWG44 - 44" MINI HYD WOOD GRABBER (A54757)
UNUSED FUTURE...
Unverferth Gravity Wagon (A50775)
Unverferth Gravity...
